Results 21 to 27 of 27
- Aug 2012
- 61
September 28th, 2014 12:12 AM #21
- Aug 2005
- 553
September 28th, 2014 10:46 AM #23Yes. Jay Leno uses the same solution for his collection as they do a great job for maintenance free corrosion inhibition.
Don't need to. They already know it.
But waterless coolants are expensive and it doesn't give them return business for preventive maintenance. So it depends on what you want to achieve.
- Aug 2005
- 553
September 28th, 2014 07:57 PM #25Thank you, glad we can contribute to your wonderment. Fortunately enough, we can't account for every nitwit's malicious imagination. ;)
Previously mentioned here:
http://tsikot.com/forums/aircon-temp...ml#post2211758
In case you're missing the point, the use of waterless coolants are more prevalent in extreme applications. The economics of efficiencies differ across segments. For large diesel engines its a matter of increasing efficiency and extending engine life. For cars its mostly for preservation.
And if you were to ask the obvious again, yes we work with waterless coolants regularly. This is industry insight meant to aid people who are asking not people trying to know it all. So try not to get too touchy about this matter.Last edited by EVO-V; September 28th, 2014 at 08:02 PM.
- Oct 2014
- 162
April 2nd, 2015 11:56 AM #26Natanggal yung Rad Cap that resulted to my radiator to loss all its content and resulting to overheat. I put about 8liters of water muna as i still have to check responses either to bring my ride to a mechanic before replacing coolant. Initially replaced the cap and check this morning and still ok. My concern is if its ok to replaced my radiator with coolant and not anymore bother to bring it to a mechanic? TIA.
- 54,186
April 2nd, 2015 12:01 PM #27
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
