Results 11 to 20 of 61
March 30th, 2018 01:34 AM #11
A bit of caution here:
Most thermostats starts opening at around mid-70-80°C and are completely open by around 90°C. Most engines' optimum operating temp ranges between 95-105°C. There's no need to replace the thermostat unless it is defective. Using a replacement part that opens at a colder range will not solve a cooling system fault that is caused by something else. Besides, making this mod will more likely than not prolong warm up times for that engine.
Also, tweaking the radiator fans to always spin at high speeds (even if the ECU is requesting low) will likely shorten their life. You could end up with dead radiator fans in the middle of a trip..... and then you're really in a mess.
March 30th, 2018 01:45 AM #12
March 30th, 2018 02:07 AM #13
Both true. Never touch what ain't broke.....As cars age, stuff deteriorate....& there's always that temptation to keep expenses low on old cars that have already depreciated next to 0 value.
You still have to know your car well before doing these specific tweak options. Having a full time gauge, which I always opt for, helps the behavior observation. A lower temp thermostat in our conditions won't delay reaching optimum op temps long, though. They will still be operating at their designed normal if the system is healthy. It can however delay calling the fan in, which should help the fan life a tiny bit.
On fans, I'd only service those that lost the low....to simply squeeze out whatever life remains from the OE. They mostly can outlive hobo replacements anyway. Depending on make, OE fan motors run on high when AC is on....& AC is almost always on in our kinda use. My recommendation, always, is once that low resistor dies.... be ready w/ a new 1 in your parts bin whenever you can. It's not uncommon to see those who did still find the new fan in his storage w/ the car long gone to a new owner.[emoji4]
March 30th, 2018 02:15 AM #14
- 54,198
March 30th, 2018 02:23 AM #15
March 30th, 2018 09:33 AM #16
Not meaning to start a debate, but yes, it will delay the fan operation for a total of... get ready for it..... once per engine warm up. In all practical sense, it doesn't help. Once the engine gets to optimum temperature, the thermostat remains open until the engine is turned off and allowed to cool.
Using resistors as a means to control the radiator fan speed seems like a bad idea. A/C cabin blowers that uses this type of speed control have the power resistors installed downwind of the blown A/C air... to cool them. Despite that, they still burn out and fail. Much more when subjected to the kind of temperature in the engine compartment.
Anyway, most modern cars use a less wasteful method of controlling radiator fan speed. On Hondas for example, they have a network of relays that routes the electricity to the two fans to control their speed. For low, both fans are connected in series, in which each fan receives approx. 6V DC. If the ECU asks for full speed, the fans are connected in parallel and each fan receives full 12V DC.
March 30th, 2018 09:41 AM #17
Not meaning to either, sir. I've seen a few boasting of tweaked thermos fully open...thinking they've 1 less part to worry about. It's their car.
Different makes do stuff slightly differently. On older euros, they use resistors & relays on single fans....& divas as they are, those are the 1st to go w/ the fan motor having so much left to serve. Nippons do em better...almost always, they perfect what the euros intro.[emoji4]
March 30th, 2018 12:29 PM #18
March 30th, 2018 01:09 PM #19
By the way, at 73c the needle gauge already points at the normal level (slightly below middle) and even at 110c it stays the same.
Connected ba yung gauge sa engine coolant temperature? Or independent sila. 73c seems too low for a normal operating temperature of a diesel engine. Baka busted na tung sensor ko.
It goes back to 96c kapag idle.
March 30th, 2018 04:05 PM #20
Ok pa kaya water pump ko? Kinunan ko ng video while the engine is at operating temp with the rad cap open.
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
