Results 11 to 20 of 22
February 5th, 2014 08:11 AM #11
Sir naka vti ako, ganyan din sakit. Pero ung akon nakita ko sa hoses.
Ang ginawa ko nahlagay ako ng coolant na matapang ung kulay, say red, green or etc. Then testing, nakita ko na ung leak eh paunti unti sa may hose connection dahil sa tuyong kulay ng coolant.
Try mo sir baka makatulong.
Posted via Tsikot Mobile App
- Apr 2012
- 80
February 5th, 2014 09:26 AM #12Hi sir dongsky07, thanks sa suggestion po. I tried this one pero ganun pa rin eh. Napansin ko may tulo na sa umaga sa garahe namin pero not that much.
Thanks din po sir sa suggestion, itatry ko po ito next time kasi nagkaproblem naman yung sa AC ko kaya AC nlng muna uunahin ko.
February 5th, 2014 10:19 AM #13
^^ alright kung taga cavite ka meron mahusay at mutang gumagawa ng ac sa queensrow. Mas mura pa piyesa niya sa evangelista at banawe. Di ko nga alam kung san galing eh
- Apr 2012
- 80
February 5th, 2014 01:06 PM #14
- May 2014
- 10
May 13th, 2014 04:30 PM #15I think it's in the hoses. The clamps may be loose. Check this article out - The Causes of a Leaking Radiator Hose ? And how to fix one - Roberts AIPMC Blog. Hope it helps. May leaks din ba when your car is idle or not running at all?
- Sep 2014
- 4
- Apr 2010
- 742
September 13th, 2014 02:56 AM #17I have a Federal Mogul 0.9 cap, new hoses, napa overhaul na rin ang radiator some time ago. A small cup or less ang water loss sa akin every week - di ko alam kung normal ito, wala namang overheating. On 50/50 coolant:water mix.
- 54,186
September 13th, 2014 10:10 AM #18In some cars, the source of the leak is the water pump. If this component is hidden from view, detecting the leak is difficult.
- Aug 2012
- 2,767
September 13th, 2014 11:59 AM #19ang normal is walang mababawas na coolant. pero kung nagbabawas ng 1 small cup per week, malakas na leak yan. kung 1 small cup per year or kahit every 6 months, tolerable pa siguro.
kahit may leak sa system, walang overheating na mangyayari basta di maubusan ng coolant ang radiator mo. kaya check coolant level always and top up when needed.
- Apr 2010
- 742
September 13th, 2014 12:05 PM #20
Alam ko it's ot pero would it be the same kung sa ibang high-end models nila basta hindi pila? For...
6th Gen Mazda MX-5 Miata
