Results 21 to 30 of 45
April 16th, 2007 06:08 PM #21
Higher coolant levels means higher boiling point due to the ethylene glycol having a higher boiling point than pure/distilled water. Even if coolant is called "antifreeze" it is recommended in temperate climates as well because it allows a higher margin of error for overheating.
- Apr 2007
- 24
April 16th, 2007 09:39 PM #22hmmm.. so ano pong recommended niyo po sir sa mga lumang makina to prevent corrosion or rust? what coolant? iron block po yung engine ko.. thanks!!!
April 16th, 2007 10:33 PM #23
- Apr 2007
- 24
April 16th, 2007 11:27 PM #24thanks po sir! siguro para sure, ipa overhaul ko na ulit yung rad ko.. then pagkauwi, flush the water away.. hehehe.. tas lagyan ko na nung mixture na sinabi ni sir 2Dmax.. another question.. Off topic, meron naman kaming galon na container dito, saan kaya may water station ng distilled water? mostly kasi puro purified eh.. hehehe.. juz kidding! thanks po sir!
April 16th, 2007 11:48 PM #25
Badkuk,
Kukuha na lang ng kulang na water sa expansion tank when engine cools down. But dont let it run for long distance. Kung matapang ka naman you can open the radiator cap when it is already in operating temp. Let the steam out carefully before you fully open.I suggest caution.
Battery water is the same as distilled water.
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 17th, 2007 04:45 AM #26before you start preventing it, make sure wala syang kalawang ngayon palang.
a good indication is where the upper and lower radiator hoses meet the engine. normally kung may kalawang na yung part na yun then pati loob ng makina nyo meron narin.
April 17th, 2007 01:06 PM #27
And be sure you get all of the old coolant out before you put the new stuff in. Different types of coolant aren't supposed to be mixed.
Matagal paalisin ang rust. I think there was a Servitek around here that had a machine to run fluid through the coolant system till it was clean (parang dialysis machine para sa cooling system). I tried it at home before, and I wasted a lot of water and still saw rust coming out...
- May 2004
- 903
April 19th, 2007 01:28 PM #28Question lang po... Lagi po nag babawas ng water... although I use my car for short trip lang kaya lang baka maubusan ng tubig pag long drive na... Radiator po wala namang leak Water pump Bago po... Yung mga fan umaandar naman po ng maayos. Ano po kaya Problem?
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 19th, 2007 05:23 PM #30
run your engine w/o the radiator cap till working temp. (1/3-almost 1/2). at idle, tumataas ba ang tubig? if so, have the thermostat checked, baka di na nag-oopen ng maayos yan.
if the water in your radiator spurts out violently(like what happened sa liteace ko) have your cylinder head resurfaced, valve reseating and re-lapping and cylinder head gasket replace(in short, have a top-overhaul)..
kung *idle slowly parin ang pagakyat ng tubig despite na napalitan/ni-remove mo ang thermostat, its a sign na either weak ang waterpump mo/may bara sa system at di makacirculate ng maayos/ sign na premature/humihingi na ng top-overhaul..
na-overheat mo na ba nga pala ride mo? its one of the causes kaya isipin mo mabuti..
basta ko, mga MAY, total flush na ako sa cooling palit na ako sa usual mix ko -> 80/20 coolant/water mix (liteace ko: 6liters=4.5liters coolant+1.5liter manila pure d.water)
Isuzu pala makina, at least madali hanapan ng parts.
2022 Mazda BT-50 (3rd Gen)
