Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Does refrigerant brand matter(KLEA,Kalton,Doowon) in the effectiveness in the air conditioning system? Is one brand better than the other?
    Oct 2009
    I think its like buying fuel. The better one is usually the most expensive one. In terms of freon. The quality lies in the mixture of refrigerant and oil and the quality of type of oil and of course its purity.
    A bad quality freon would have a very small percentage of air and other gases along the refrigerant.
    Aug 2008
    Quote Originally Posted by franzhelmer View Post
    I thought a good quality refrigerant would have a very small percentage of impurities.
    Oct 2009
    Quote Originally Posted by den1106 View Post
    I think its just a grammar misconception..
    Good Quality = no impurities such as air and other different gases. It should only have Refrigerant freon+Oil.
    Bad Quality = Has small percentage of impurities.
    Really Bad Qaulity = Has large amount of impurities including rust hence aircon will never get really cold and lines will get clogged up and mess with other components such as the condenser (Holes and lines of condenser are very small and dirt can clog this easily).
    Sometimes people just use old empty freon tanks which contains already rust inside! This rust will go into your system. Then you begin to wonder.. Bakit ayaw lumamig aircon ko? Lolz
    To prevent this there is a freon filter used for charging.. Then again most or no airconshops consider this.
    Kaya best way to fill and recharge your airconditioning unit is DIY. Get your equipments such as own vacuum pump,gauge,tank and filter.
    This price will not exceed 6k php. And in my opinion it's worth it. Since you can recharge your own Aircon (if its 134A as well),Ref,other cars and your own car at home. So its really worth having one. And of course a good trusted place to buy clean contaminant free freon refrigerant.
    The scam lies is that you cannot see what's really inside their tank or your tank. Even the hoses are colored.
    ^^ bro may idea ka ba kung magkano ang per kilo ng R134A jan sa PINAS? thanks
    Aug 2008
    Quote Originally Posted by bambino View Post
    I think it is around Php350.00 per kilo.
    thanks for the quick reply bro , I APPRECIATE.
    Sep 2008
    Freon is a brand name owned by Dupont
    Sep 2008
    Quote Originally Posted by warrior View Post
    No. types of refrigerants does. Ammonia is the best because of high boiling point.
    Efficiency to cool is the method of measurement. That now depends on the design of the system and the machines.
    Aug 2009
    Quote Originally Posted by bmacavanza View Post
    plus ten ako sir
    wala sa brand ng refrigerant ang mahalaga pulido gumawa ang technician mo, at wag gumamit ng recycled na refrigerant most of the shop used recycled para makatipid lumaki at ang kita
R134-a refrigerant brand
