Results 1 to 10 of 16
- Apr 2009
- 272
April 9th, 2015 03:21 PM #1ano magandang coolant? mas ok po ba yung no need to add water? I always see this prestone coolant sa mga stores. baka may iba pang mas ok.
April 9th, 2015 03:36 PM #2
Gamit ko yung Peak Long Life Coolant concentrate. Sa Label niya 5 year or 150,000 miles. Php.1.2++ yung 1 gallon niya. Meron sa True Value or Handyman. Make sure lang to use distilled water pang dilute sakanya.
April 9th, 2015 03:37 PM #3
Prestone should be good enough. Meron din silang pre-mixed na in gallon jugs. No need to add water.
- Apr 2015
- 140
April 9th, 2015 04:01 PM #4Try Pro99. Had it used sa Ford lynx ko. No problems naman. As long as tama yung timpla. 50-50.
- 54,186
- Oct 2009
- 21
April 9th, 2015 08:40 PM #7I've been using Prestone for the longest time. Wala namang naging problema sa naging mga sasakyan namin.
- Apr 2009
- 272
April 9th, 2015 08:45 PM #8how many liters ba kelangan ilagay sa radiator lets say if im going to use the pre mix coolant?
- Apr 2009
- 429
- Aug 2012
- 2,767
April 9th, 2015 09:51 PM #10Depends sa size ng radiator. Nakalagay sa user manual kung ilan liters ng coolant ang kailangan ng kotse mo. Example, 4.6L for Toyota Yaris. This means you need 4.6L pre-mixed coolant.
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
