Results 1 to 10 of 16
- Nov 2008
- 10
April 24th, 2009 11:59 AM #1When I use Aircon, I can smell the outside air. Especially when there is a smoke belcher in front or pag meron nagsisiga sa daan, the smoke penetrates and blown inside.
A taxi driver said to me that it is my AC evaporator that has a problem. Is this true?
April 24th, 2009 12:36 PM #2
^nope, the problem is your air vent, air circulating vent yata ang tawag....you can have it permanently shut off pag nagpa cleaning ka ng A/C, unless ginagamit mo siya...
common ganyan sira pag medyo luma na ang car...
April 24th, 2009 01:02 PM #3
check mo rin while the a/c blower is off. pag meron, check mo firewall baka wala na mga goma and tuloy tuloy na outside air. kung pag naka a/c on lang sa vent nga.
April 24th, 2009 04:21 PM #4
What is the ac evap got to do with it? The culprit is the vent flaps not totally shut. When your ac is switched to circulation mode, the flaps shuts off preventing outside air to sip inside the cabin. Vent flaps has attached foam to seal off outside air from coming in. These sealing foams gets worn out in time especially on old vehicles thus the problem with outside air getting in.
- Nov 2008
- 10
April 25th, 2009 12:30 PM #5Thanks guys! I will have my vent flaps check then and I do have an old car.
May 13th, 2009 08:14 PM #6
Ganun din sa esi ko, amoy mo yung usok ng mga jeep pag nakahinto sa stoplight. Saan kaya pwedeng ipagawa ito? Thanks sa lahat.
May 13th, 2009 08:55 PM #7
May 14th, 2009 09:44 AM #9
- Apr 2007
- 5
July 3rd, 2009 12:29 AM #10Do you have the foam replaced? Is this an easy part to buy? how much does this usually cost?
Thanks in advance for your replies
One can only hope.
