Results 1 to 6 of 6
    Question po. My aircon heater hose cracked recently and spilled coolant all over the engine. I was kinda thinking, will my aircon thermostat still work if i just put a bypass hose and not run the coolant to the heater core. No one uses the heating function of the climate control here anyway. My car is a civic EK with an aftermarket 3row radiator. tnx guys...
    Jan 2003
    did it to my vitara and my sister's CRV, mas malamig aircon,
    some say kasi kahit hindi mo gamit, the heater core is still hot and radiates the heat to the cooling side of the aircon duct.
    Aug 2005
    Quote Originally Posted by atsuete View Post
    You should be able to take that out just make sure you disable the electrical systems activating it as well.
    Then again you won't be going to Baguio anytime soon are you?
    on the contrary, if your ac is atc you're using the heater without knowing it. paano? dito mo nacocontrol ang desired cabin temperature setting mo. kinokontrol and blend air mo para ma achieve ang desired temperature mo.
    another disadvantage pag bypass ng heater core is in case of overheat and you cannot stop immediately..pwede makatulong yung heater core and blower para wag masyado tumaas temp.
    Aug 2005
    Quote Originally Posted by t2erns View Post
    Its an old Civic EK, I don't recall those being released with climate control.
    Essentially the functions of cooling have more to do with the A/C and airflow rather than mixing air.
    There are a host of vehicles on the road without heater cores.
heater bypass
