Results 1 to 5 of 5
- Apr 2008
- 99
April 25th, 2016 10:42 AM #1Hi sirs,
Just had my car compressor replaced about 2 months ago. My issues is when in heavy traffic and on a hot day around lunch time, the compressor does not seem to disengage to the point of 1 time overheating in EDSA at 1 pm.
Morning, afternoon or evening it’s automatically engaging/disengaging. Brought it back to the a/c shop and according to them the system seems ok.
Any ideas why it’s not disengaging when in heavy traffic and on a hot day?
Thanks!
April 25th, 2016 11:19 AM #2
To me, the A/C is working normally.
What car?
What setting did you set the A/C thermostat to?
On a hot day, it's normal for the A/C to work harder to maintain the temperature inside the cabin. But no matter what, the A/C should not cause the engine to overheat. Something else is then inherently wrong with the engine's cooling system. Check radiator fans, coolant level and condition, engine thermostat valve condition, radiator, etc.
- Apr 2008
- 99
April 25th, 2016 11:29 AM #3
- Apr 2008
- 99
October 3rd, 2016 10:10 AM #4Sirs, update lang on this. My air con's working fine now but I have another issue:
Few minutes after staring the car I notice that my compressor is short cycling or it's rapidly turning on and off (1 second on - 1 second off). After the engine has fully warmed up it operates normally.
Ano kaya possible cause nito? Brought it to an AC tech and said that my the evaporator thermostat is faulty. Any thoughts?
Thanks!
October 3rd, 2016 10:51 AM #5
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
