Results 1 to 10 of 11
- Nov 2008
- 641
April 6th, 2016 12:57 PM #1My ageing Corolla had its Heater core leaked, and was forced to just remove it thinking that it was a good idea since we really don't need heaters in our country. I was also aware of the cost if it need replacing, thus the removal. I temporarily blocked the supply hoses using the available plugs in the market. My dilemma is that I really don't know which one is better, Blocking or Bypassing. Some say plugging will cause restriction in coolant circulation (if the thermostat is closed), while Bypassing reduces pressure in the system. I don't know which one's best for my engine.
I will appreciate thought regarding this. Thank you!
April 6th, 2016 01:08 PM #2
Bypass.
Jury rig a pipe with flexible extensions on both ends for it.
I have old cars too, all are bypass.
April 6th, 2016 01:21 PM #3
April 6th, 2016 01:32 PM #4
I'd like to think so. My bypass tubes are all outside already (engine bay) where its easy to check should they leak. The system holds a bit more coolant too (as compared to a plugged one), so I think that's one benefit there.
April 6th, 2016 01:45 PM #5
I think most Japanese FWD engine designs route the bypass under the intake manifolds between the block and the firewall.
- Nov 2008
- 641
April 6th, 2016 02:16 PM #6
April 6th, 2016 02:48 PM #7
The shop did that to the jimny when they replaced the compressor. They bypassed the heater tubes.
- Nov 2008
- 641
April 6th, 2016 05:14 PM #8
- Oct 2009
- 2,271
April 6th, 2016 06:50 PM #9bypass mo nalang ..
sa akin sa civic ko nag leak sa loob kaya ginawa ko binaypass ko nalang wala namang epekto sa cooling system.
- Oct 2013
- 2,537
April 6th, 2016 08:50 PM #10blocking, just like what we have with the vios, 1 & 2 nz-fe have pipes from the water pump going to the heater core in the cabin... but since the vehicle in the philippines are not fitted with a cabin heater core, said pipes are blocked by a rubber plug...
if you maintain a good coolant system it shouldn't be a problem...
Telo Trucks Telo Trucks - Wikipedia BIG TRUCK ENERGY! Exclusive First Drive of the Telo MT1...
Telo Trucks
