Page 35 of 69 FirstFirst ... 2531323334353637383945 ... LastLast
Results 341 to 350 of 1163
    Mar 2003
    hmm...parang nandun ako last dec. 23 ata yon...so i guess open den sya ng 30...=)
    kakagising lang nga ni mang mario nung pumunta ako kaya mejo masungit...pero after a while, kwentuhan na.=)
    and i'll say mura talaga! will definitely go back pag may prob ulit.
    Sep 2004
    went there last december din before christmas. nawala lamig ng aircon ko. his son removed my evaporator, filled it with air and saw that there was a leak. i was expecting to hear that my evaporator needs to be replaced. but his son said that he might be able to repair it and so he did. he welded the leaking part and tested it (no more leaks!), cleaned my evaporator, then he reinstalled it. after the work, i asked mang mario's wife how much my damage was while in the process pulling out 3 P500 bills. to my astonishment, she said that my bill was P800 only! now that is cheap! and all that work was done in 45 minutes! what can i say? i was amazed by this family. may god bless them.
    Depende sa area ng leak kung magagawa. Kung kaya, they will repair it. Na-try na din namin dati, tumatagal naman.
    Dec 2002
    malas ko yesterday may fun run ang pajero clan ng mymitsu. Nung pauwi na ako bigla nalang ayaw mag on ang compressor. Nakita ko pumutok ang fuse. Inisip ko baka kasi luma ng yun fuse kaya lagay ulit ako ng bago. Naks pumutok ulit. hay gastos uli baka shorted and clutch ng compressor sa linggo ako pupunta kay mang mario. Buti otep laki talagang tulong mo sa pag refer sa amin kay mang mario
    Quote Originally Posted by johnart
    Yung magnetic clutch ko nasira din after sustained high speed travel. Hindi kaya yung pag-engage-disengage ng compressor while being spun by the engine at high speeds ang salarin?
    theveed,
    Tanggal freon niyan. Baba ang compressor, eh. Pero hindi Calsonic pinagawa ko nun.
    Sino nakapaggawa na ng compressor bearing replacement kay Mang Mario na calsonic? mga magkano inabot?
    Also, pag pinalitan bearing, tanggal din ba freon? If so, pwede na isabay R134 conversion?
    Sep 2005
    ask ko na rin sa inyo guys! ano-ano ba kailangan palitan kung ipa convert ko sa R134 ang aircon ng auto ko? at magkano kaya ang gastos dito?
    TIA
    Betz: Please do a search, may mahabang thread na about that.
    Mar 2003
    may magagawa pa kaya si mang mario para lumamig aircon ng hyundai H100 namin lalo na ngayon na kailangan na mag pa convert to r-134a diba mas mahina daw ito magpalamig.
    Dec 2002
    otep,
    no idea if high speed is the culprit but I drive more faster with a galant vr and had no whatsoever problems with the magnetic clutch. Maybe its a defect by the nippondenso compressor ? Mit Air sa galant. Baka sa pag off road nababasa
Aircon Repair: Mario Reyes
