Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 174
    Apr 2010
    Terrano JDM. Nung unang kuha manginginig ka talaga sa lamig, pero ngayon hilaw ang lamig. Hindi pa pala nakakatikim ng cleaning ito for 7 years
    Malamig kung maganda panahon, pero pag tanghaling tapat or kahit hapon hindi malamig
    Hilaw pa rin ang lamig kahit at highway speeds pag mainit
    Hilaw din kahit buhusan mo ang condenser
    Drier(?) yung contraption na may glass may bubbles
    May nakabalandrang tube sa side ng air filter ko, so when I check it once in a while, pag ginalaw ko yun may sumisingaw (freon?), also may kakilala ako na sinabing hinawakan nya isa pang metal tube almost above the engine bay, dapat daw malamig yon. I see it dripping although at a very slow rate.
    Sa center console, yung left air duct parang hangin lang, while yung right malamig, plus parang may lumalabas na hangin from the footwell kahit hindi nakadepress yung switch para don.
    So rule out compressor? Possible dun sa tubings na i've mentioned? Possible din na sira na ang evaporator?
    Magkano kaya to have these tubings replaced, cleaning, at flushing ng system? Estimated cost ng evaporator?
    We can keep on guessing all week. But why not just have it checked over at an auto-aircon shop? It doesn't cost much for a check to be done and you'll know what is really the problem with your AC.
    Jul 2010
    Call this number 984-4881 and look for Anthony of CoolSpeck. At least you can have idea how much it will cost you.
    Jun 2011
    malaman sir may leak dun sa may drier... dba kamo may sumisingaw pag ginalaw nyo.... baka loose lang ang fittings...
    Jan 2012
    Sulit ka na diyan 7years, pa servisan mo na, kung butas ang evaporator around 4k yon mataas na yon, ang refrigerant 134a ngayon nasa 500/kilo nalang, ang mahal diyan yun talent fee ng gagawa...
    Dec 2009
    pa general service mo aircon system...
    -check for leaks sa system
    -check clutch fan mo kung ok pa( pinapalitan talaga iyan, it will cause high pressure sa system pag madulas na kaya mahina lamig.)
    -check the compressor itself ( ok pa ba yung pressure generated at both Low side and High side)
    -check the condenser ( baka madumi na puro insect at mga dahon dahon at iba pang dumi) less airflow kaya hihina exhange ng heat ng freon)
    -check if freon is at correct level( baka kulang lang, pag kulang meh leak yan)
    -check and clean you cooling coil ( baka madame na din dumi o alikabok, at meh mga flux residue sa fins kaya again less airflow)
    -check the drier/humidifier ( napapalitan din yan)
    -check expansion valve ( baka madumi na at barado ) be sure na orig na expansion valve lalagay
    madame shops gumagamit ng china na freon o kaya mga unknown brands.... mas ok if US brands dapat makita mo yung tank nila ng parang gasul na maliit... wag ka papayag pag freon eh galing sa isang canister that looks like refillable... baka peke yun..
    Quote Originally Posted by ParticleX View Post
    ~ 13 year old honda CRV 2.0 liter. exactly ganoon ang symptoms. It all happened one day when biglang walang lamig. busy ako so pina ayos ko sa relative ko na amatuer mechanic. pumunta sya sa local aircon repair shop owned by his friend. butas evaporator. new evaporator + freon + labor cost 6000. symptoms like the above happened after ma ayos.
    so since humina ang aircon after ma replace ang evaporator I assume na either maliit/low quality made in china ang evaporator or maybe somethings wrong with the freon. magkano kaya ayusin ito, using a good quality evaporator?
    Apr 2010
    Quote Originally Posted by vmaldia View Post
    it should have been a back job right? there could be a slow leak in your system, have it rechecked
    its been a couple of weeks. the quality of the cooling ahs not changed. doesnt that suggest that its not a leak? of course only checking the freon with a shop's meters and guages will show it for sure
    Oct 2011
    may leak na yan sir ala na freon kaya hindi na malamig.
Aircon di kinakaya pag mainit
