Results 1 to 10 of 91
- 3,754
October 5th, 2004 05:09 AM #1Any suggestion to solve this problem, Im not sure if the piston was been oversize before.. Cylinder head was changed and top ovehauled also done, Probem is During High Rev * speed of 120km/hr temperature increasing, Im thinking of adding additional Fan but where to put it,
It also overheat during trapik if the AC is on but up to 50% gauge reading, I have done routine radiator cleaning.
Suggestion Please.!!!!!
October 5th, 2004 07:17 AM #2
before nag change ng head nag overheat ba ito? re-adjust valve tappets.
October 5th, 2004 08:10 AM #3
I'm thinking of adding an additional fan too. 4d56 din po. Hope to hear suggestions where to put it and shops that can do this.
Nightrock,
Try to remember kung nag-ooverheat siya before the overhaul. Medyo hindi yata typical na mag-overheat at high speeds. Yung sa traffic pwede pa. I experience this all the time. Well, not exactly overheating but rising temp talaga.
Tsikot Member Rank 3
- Dec 2002
- 636
October 5th, 2004 08:51 AM #4NightRock
Have you changed the water pump and thermostat? Old pump may not have enough water flowing. If no thermo, water can flow too fast with insufficient time to cool in radiator.
Also check the clutch fan- may be too soft due to old silicon oil, just replace silicon oil inside clutch fan.
October 5th, 2004 09:44 AM #5
I'd go with what Jackaroo mentioned... check the thermostat and the water pump.
A stuck-up thermostat will usually slow down coolant flow so when the engine is revving/moving, the heat builds up.
One symptom of busted water pump is that you lose water when the engine is running.
Kung medyo luma na pareho at di pa napapalitan, maybe it's time to do so na rin as it's not that expensive for those parts.
- 3,754
October 5th, 2004 10:23 AM #6Originally posted by jackaroo
NightRock
Mukhang eto palang ang hindi ko pa na Try... it was over heating even before overhauling.... I have also notice na mababaang oil pressure..
But there is no sign na sira na ang water pump. well medyo nag babawas nga ng tubig pag tumataas ang temp during up to 50% gauge reading .. is it possible that water pump can be paritally chocked?? that can cause low supply of water during runningLast edited by NightRock; October 5th, 2004 at 10:27 AM.
- Sep 2003
- 287
October 5th, 2004 10:42 AM #7NightRock,
radiator cleaning- was this done with LavRamon sabay coolant /water mix replenish????
Para lang may checklist and process of elimination:
1. insufficient coolant in system
2. drivebelt defective or not adjusted properly
3. radiator core blocked or grill dirty or restricted
4. thermostat faulty
5. fan not functioning properly
6. rad cap not maintaining proper pressure
7. ignition timing incorrect
8. defective water pump
9. improper grade engine oil
10. inacurate tem gauge
NOTE: troubleshooting list covers 4g54, v6, 4d56, 4mf40
HAYNES 0-21 sec 27
- 3,754
October 5th, 2004 10:50 AM #8rlp1099
I dont exactly know what is this LavRamon process as I have done ratiator overhauling medyo maramni nga dirt na nakuha , I have tried water/coolant mixture too.
Radiator cap pinalitan ko na din, Dati fully synthetic sya mas ok nga medyo hindi umiinit pag nasa trapik, Yung temp gauge Ok naman nag zero check ako while running inalis ko yung connection.. nag zero naman. thermostat nalang at water pump ang hindi ko pa na papa check.
Thanks
- 3,754
October 6th, 2004 05:58 AM #10Originally posted by Dieseler
Nightrock,
When is the last time the Water Pump was replaced?
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
