Yikes, sa akin lead glazing nung last time.
where is the info mga peeps? I can't see them. any links for this thread; A sparkplug's story?
it's on the picture attached sa post ko. baka nakafirewall ka kaya blocked yung webhosting site.
[SIZE="1"]Hmmmm.... PWEDE!!![/SIZE]
nice thread.. up!
...given na walang problema ang engine. ano ba lifespan ng sparkplugs? sinasabay ko kasi lagi pagpalit tuwing oil change eh (every 10k). malinis naman lagi itsura nung luma.
When installing new spark plugs, do i still have to check and adjust the gap or naka set na ba yon from the box? Tnx.
Hi everybody,
I share the same query SCARAB has over the use of sparkplugs.In my case, once in every six months I tried to draw those four sparkplugs out, and clean the contacts but do not really know, or has not monitored, how often had I replaced sparkplugs over the last decade. Sometimes I replaced them in 1 year, 2 years, and in extreme cases even in 3 three years, depending on the brand. Kasi I usually experiement with different brands. Basta manipis na palit na. Is there really a hard and fast rule of changing sparkplugs other than the obvious, before you get stalled in the streets? Like all other consumables, maybe there is! What do you say?
we usually change sparkplugs every 6 months, coz every 6 months tune up namin. at 1 time, we bought bosch sparkplugs, they say you can change it after a year pa. ok namanbut its expensive hehehe
salamat dito.... thanksthanksthanks!
Mga bro need help
Ano ba sakit ng sasakyan pag madalas pumalya ang makina?
Pina-overhaul ko na ang carburador
Na-top overhaul na ang engine nung january pero palyado na uli ngayon
Kelangan bang platinum sparkplugs na ang gamitin ko,hinde yung pangkaraniwan lang?
Yung sparkplug malakas at mabilis mag-karbon tulad ng nsa pix.
Carbon Fouling
Ano ba ibig sabihin nito:
1) Over-rich fuel mixture - (mali ba ang gaso na kinakarga ko?)
2) Carburettor mixture settings
3) Float level
4) Choke operation
My mga nag-suggest sakin na ipalinis ko muna ang Gas Tank, Fuel Pump Filter & Air Filter baka daw madumi na at baka sakaling yun ang cause ng pagpalya ng makina dahil sumasama ang mga kalawang o dumi sa pag-akyat ng gasolina.
Bka may iba pa kayong suggestions kung paano maiiwasan ang pagpalya ng makina, paki-post naman po.
Your immediate response would be very much appreciated.
Pwede nyo rin ako iemail sa mga replies nyo -- po1.migs@zipido.com
Thanks
| Tsikot Car Finder Latest Car Listings Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now! |
Bookmarks
