Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Window Treatment Thread, sunroof problem in More Than Looks; mga sir, pahelp naman ng konte.. naglileak na yung sunroof ko.. =C where can i bring it kaya?? para mapagawa?? ...
Results 1 to 2 of 2
Thread: sunroof problem
  1. #1
    Join Date
    Default sunroof problem
    where can i bring it kaya?? para mapagawa?? and how much nadin..
    thanks in advance mga sirs...
  2. #2
    one shot v6dreamer's Avatar
    Join Date
    May 2007
    Location
    Wild Wild West
    Default Re: sunroof problem
    There are drains in the corners of the sunroof tray, they have a tendency to get backed up(clogged) that is why you said its leaking. Try cleaning the drain hole first.
    Locate the drain holes and the nipples. (hehe) There are a total of four drains, two front, two rear. The front drains empty out inside of each front door jam as you can see in the photo below. The rear drains empty out inside of the rear bumper (on some models). To check the rears, you will need to reach up inside of the extreme lefthand and righthand sides of the bumper and feel your way around.
    You can clear most of the gunk and garbage out of each drain by squeezing, twisting, and performing any other questionable action on each drain NIPPLE. I would not recommend "biting it"(squezze you may) because as you squeeze it, dust, debris and/or water (if it was slightly clogged) will fall out of the drain.
    Locate the drainage of your car where the red circle.
Receive Latest Cars For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
