Yung iba takot na takot mag apply ng wax pag naulan. Dapat nga mas lalo ka mag wax dahil protection yun at mas madali linisin dahil dumudulas lang yung ibang dumi. Just invest in a high durable wax tapos maintain ng pang quick detail.
Metro Manila:
24°C to 34°C Light to Moderate: East-Northeast
Manila Bay: Slight to Moderate
Metro Cebu:
25°C to 30°C Light to Moderate: East
Coastal Waters: Slight to Moderate
Metro Davao:
23°C to 31°C Light to Moderate: East-Northeast
True that, I've said it before if it's not a life and death situation no way lalabas ako ng midday. Nakakamatay yun init ngayon! Pag labas mo pa lang eh maramdaman mo na Sa mukha mo yun init, it's like looking down at an engine bay
had to go out for lunch kasi gutom na talaga ako
sakit sa balat ng init
pag gabi hindi na kinaya yun aircon kailangan pa bukas yun electric fan![]()
mukhang kaya pa naman ng power plants natin sa luzon yung demand.
wala pang rotating brownouts eh.
mahina kita ng powergen stores ngayon........![]()
kaya ko pang tiisin ang init ng haring araw huwag lang ang ulo ni esmi ang uminit.
So far, kaya naman but this cannot be sustained for long given the continued demand growth. Thankfully my house is surrounded by large trees so direct sunlight is only a problem in the morning until noon time since the front (w/ no trees) is facing the east. Even when i was choosing a condo unit, i studied the orientation of the sun just to ensure i get one that isn't going to be baking in sunlight most of the day (I avoided the afternoon sun actually).
Given these, those who are planning to build their houses should always take into consideration the orientation of their house and make place to plant trees around it. It helps when the weather becomes sweltering (although you can't do much about the humidity aside from having an efficient a/c and ventilation system).
Heard on the radio that the temp would even break 37 degrees...
MANILA, Philippines - Temperatures in Metro Manila set a new record Monday afternoon when the mercury reached 36.6 degrees Celsius, the hottest since January, but residents felt the heat at above 40 degrees Celsius.
Based on the Philippine Atmospheric Geophysical Astronomical Services Administration (Pagasa), the temperature peaked at 2 pm. But with the relative humidity (amount of water vapor in the air) at 46 percent, residents in the National Capital Region (NCR) actually experienced the heat at 43 degrees Celsius.
mas mainit sa "atheist" thread.
malamang, nasa 40 deg celsius na. & it's still going up........![]()
Good thing it rained well enough yesterday. Nadilig yung mga halaman and it was a bit cooler last night (nawala yung kumakapit na humidity).
ay, huwag naman sir. ayaw ko ng makitang lumulutang ulit ref namin sa bahay.
pwede rin naman ipa-car wash ni bro greenlyt kung tinatamad mag linis. same effect din un. uulan din.![]()
