Results 101 to 110 of 391
June 4th, 2013 07:03 PM #101
Ayan, tuloy na ligaya ulit. Sorry po sa mga naperhuwisyo namin. Sorry lang ha, wala kami pera pang-refund sa mga losses nyo, budget airline lang kami. Sakay kayo ulit ng Ceb Pacific. It's time every Juan travels.
Cebu Pacific, maglalabas ng pera for the other airlines? Malabo yan, its like Lance Gokongwei shooting himself in the foot.Last edited by lowslowbenz; June 4th, 2013 at 07:06 PM.
- Jun 2004
- 1,311
June 4th, 2013 07:03 PM #102Wag masyado maniwala agad sa lahat ng naririnig online...
From what i see the plane technically did not overshoot the runway, it just went to the grass. Probaby due to the rain and wind at the time.
As for the smoke and smell naranasan ko na yan sa Cebu Pacific, dahil sa aircon, yung aircon or ventilation system alam ko powered through the engines.
As for the sound of the engines, the sound varies depending on the engine of the particular plane, naranasan ko na rin dati na parang iba tunog ng makina, pero narealize ko na dahil lang yun sa clearance from ATC to maintain a certain altitude.
And nde rin SOP to ground an airline for running into the grass. This would have an even bigger effect not only to Davao but to the whole Philippines...
- Jun 2004
- 1,311
June 4th, 2013 07:10 PM #104I would imagine the pilot is probably being investigated internally and any press releases would only come from Cebu Pacific's PR dept. Sabi nga ni Capt. Andrews malaking chance na pilot error nangyari.
June 4th, 2013 07:11 PM #105
June 4th, 2013 07:14 PM #106
- Jun 2004
- 1,311
June 4th, 2013 07:14 PM #107I saw from one of the aviation forums the location on the runway where the plane ended up, it was in the middle part of the runway. Not like the overshoot of PAL previously into houses or Zest air in boracay...
But again, this is just my opinion based on what i've read.
June 4th, 2013 07:14 PM #108
Paano hinde SOP na grounded lahat ng fleet? What if its mechanical error? Paano yun ibang same model planes na lumilipad pa rin?
Sent from my iPhone using Tapatalk 2
- Jun 2004
- 1,311
June 4th, 2013 07:16 PM #110
high idle RPM at engine start
