Results 21 to 30 of 33
- Nov 2006
- 299
August 20th, 2008 11:58 AM #21ano ba ang pakiramdam mo pag minamaneho mo yung kotse mo,talaga bang nagslip sya,kasi ang slipping ay tumataas yung rpm pero halos hindi bumbilis ang takbo nya and or nagbang sya sa 3rd gear?
BANNED BANNED BANNED
- Jul 2003
- 2,267
August 21st, 2008 09:51 AM #22
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 31st, 2008 03:09 PM #23honda automatics from the eg/ek/es models do not have at pans. neither do they have at filters. some research should be done before giving sweeping statements imo.
if you just drain and refill the honda tranny you will use a max of 4 liters of atf. if you were able to put more than that you overfilled the tranny.
- Jul 2003
- 2,267
October 2nd, 2008 07:49 PM #24I used almost 6 liters of atf but I believe I did not overfill the tranny. i just used the extra 2 liters to remove the old atf at the torque converter.
I actually checked the atf (normal operating temp as the manual says) and it is on the right level. Up to now, the ATF color is same as new and no burnt odor. But despite this, the tranny slips at 3rd gear. Based on the manual, the 3rd clutch may be malfunctioning.
Anyway, will it help if I use Honda prescribed ATF??? I used Total Dexron III when I last changed ATF.
- Nov 2003
- 3,849
October 19th, 2008 04:16 PM #25nope i doubt it will help. if the gear is slipping on new fluid then it'll slip even with honda fluid.
- Jul 2003
- 2,267
October 19th, 2008 06:09 PM #26ok thanks!
any idea how much a surplus a/t for a ph16 engine costs today?
- Nov 2003
- 3,849
November 16th, 2008 01:55 PM #28
overfilled a/t gives slipping shifts. refer to manuals when getting the right readings. ibang-iba ang reading procedure kasi ng mga sasakyan. ang iba while engine is running, ang iba needs to run a few miles first.
- Jul 2003
- 2,267
November 17th, 2008 11:44 AM #29
- Nov 2003
- 3,849
November 30th, 2008 04:18 PM #30depends if shops have it in stock. paiba iba depending on when their shipments of surplus parts arrive.
