Results 1 to 10 of 26
October 20th, 2008 02:02 AM #1
mga sir patulong naman,
kakapalit ko lang ng routine na clutch disc, pressure plate, and release bearing, may squeaking noise kasi when you press on the clutch. pero bumalik na naman after a few months... ano kaya ito?
edit: civic lxi 2000 po... everything is stock with the tranny... fcc yung brand na pinangpalit.
October 20th, 2008 05:49 AM #2
sir baka po hindi nalagyan ng greas ung sa clutch fork nya.. standard po yan sa toyota ung nag ojt po ako... san banda po ba naririnig? kung sa loob po or sa may makina? tnx
October 20th, 2008 11:20 AM #3
^^ sir thanks for the quick reply... sa may makina po nanggagaling. anong grease maganda lagay?
October 20th, 2008 05:44 PM #5
October 20th, 2008 05:45 PM #6
^^ ay hydraulic pala hehehe sorry sorry
cable pala yung lumang civic. :bwahaha:Last edited by archie123456789; October 20th, 2008 at 05:53 PM.
October 20th, 2008 06:24 PM #7
normally sa release bearing and the plate galing ang ingay kung during apak. sana bago nga and di defective ang naipalit na release bearing. ang pressure plate kasi madaling makita kung napalitan ng bago dahil malalim na yung tama from the bearing.
October 20th, 2008 06:35 PM #8
damn! kakapalit ko pa lang release bearing, pressure plate, and clutch disc... mahal pa naman labor and time consuming. hayyyyyy.........
October 20th, 2008 06:44 PM #9
pag release bearing, kung bago dapat resistant to ikot yun.. pag once installed, kung defective na yung release bearing, di squeak madidinig mo, more of a rattle...
October 20th, 2008 07:05 PM #10
archie, best thing is paglaanan mo na lang ng konti pang time, ibalik mo sa gumawa habang maaga, parinig mo sa kanya yung ingay.
