Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Transmission Talk Thread, reverse wont work from cold engine. (AT) in The Workshop; Hi guys, problem ko sa transmission ko pag cold start or pag malamig makina, ayaw gumana ng reverse shift, need ...
Results 1 to 9 of 9
Thread: reverse wont work from cold engine. (AT)
  1. #1
    Tsikot Member tonzi's Avatar
    Join Date
    Oct 2009
    Location
    QC
    Default reverse wont work from cold engine. (AT)
    Hi guys, problem ko sa transmission ko pag cold start or pag malamig makina, ayaw gumana ng reverse shift, need pa na painitin although all gears are working even if cold ang engine. anu kaya problem?
    i tried changing ECU
    i tried changing ATF oil
    i tried overhauling my engine.
    but same problem occurs. May nag suggest sakin dito sa forum na ipa replace ko linear solenoid since all gears are working naman yung reverse lang ayaw pag malamig makina pero pag mainit na solid naman ang shifting ng mga gears..
    how much kaya tong linear solenoid? and sino kaya gumawa ng tranny ko??? HONDA ESI.
    salamat ng marami.
  2. #2
    Tsikot Member Rank 2 t2erns's Avatar
    Join Date
    Location
    bulacan
    Default Re: reverse wont work from cold engine. (AT)
    much better to scan it first than shot gunning the parts.
  3. #3
    Nissan/Mazda Fanatic basti08's Avatar
    Join Date
    Oct 2005
    Location
    qc
    That happened to my Sentra and Familia before. Change tranny was my solution.
    Btw, is your car's tranny already sliding? cos that's the case with my Mazda.
  4. #4
    Join Date
    Oct 2009
    Location
    QC
    Mga sir smooth naman ang shifting wala naman sliding, bsta yung reverse lang talaga problema. san ko kayo to mapapagwa sino kaya expert? nagpalit ng computer box sir, ganun pa din problem.
  5. #5
    Join Date
    Location
    bulacan
    reverse on your tranny is the functions of 4th and reverese clutch. since you dont have shifting problems when hot; i guess your problem is most probably in the valve body (the reverse servo might be sticking) pag malamig syempre malapot pa ang atf.
  6. #6
    Join Date
    Oct 2009
    Location
    QC
    Quote Originally Posted by t2erns View Post
    so sir, ano po pwede magawa dito? yung reverse servo? is that part of the tranny?
  7. #7
    Join Date
    Location
    bulacan
    Quote Originally Posted by tonzi View Post
    the servo body is bolted to the valve body and is internal to the transmission
  8. #8
    Join Date
    Dec 2010
    Location
    dito lang sa talyer
    check mo sir yung transaxle shifter cable baka po ndi sumesentro dun sa lever. if okay po, pa check nyo po yung pressure sa reverse port ng transaxle
  9. #9
    Join Date
    Jul 2012
    Sir,singit ko n din prob ko bout my tyota camry 88. Pag malamig mkina,nd try reverse or primera,it seems parang babalik sya sa neutral or parang sliding...then most evident is pag nka hanging or inclined position,i need to use the hand break para d ko maatrasan ung sa likod ko.ano po kya ang tnamaan sa trany ko? pls share ur xperience nd pls recommend ung talgang specialist sa matic.tnx in advnce.
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
