Page 6 of 6 FirstFirst ... 23456
Results 101 to 120 of 169
    Sep 2018
    Quote Originally Posted by istan View Post
    Make use of the full range of movement of your accelerator pedal, just like your brakes. U might find it enjoyable. Ü
    Yes tama ka.. tinry ko din yung suggestion nung isang member sa gas pedal - release then quick press again ramdam mo mejo lumakas ung rev, i find it usefull kung need mo extra kick [emoji4]
    Sent from my SM-A710F using Tapatalk
    Sep 2018
    Another, does switching OD off consumes more fuel?
    Jan 2010
    Mar 2018
    Quote Originally Posted by reymund View Post
    Presumably since the RPM will be higher compared when OD is on.
    Sep 2018
    Agree [emoji4] thanks.
    Feb 2015
    How to reach 6K rpm in a 4AT? The manual says that #2 shift should not exceed 80kph.
    Car is NA at 155hp * 6K rpm.
    Quote Originally Posted by kebloks View Post
    I reach 6k rpm all the time with my 4AT car. Just use the manual override function - either put it in 2 or use the manual mode and select second gear.
    What car is this?
Question re Automatic Transmission Driving Technique
