Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Apr 2012
    Hi guys! I think i have a problem with my 2009 GLS monterosport, while i was going up marcos highway going to baguio my gear is being stuck in second gear kahit pag naging patag na ung daan nasa second gear parin. so what I did was to put it in neutral and naging ok naman pero pag paakyat na ulit na stuck nanaman sa second gear.. patulong naman po kung ano sa tingin ninyo ang problema.
    Jul 2004
    did you try manually shifting the gear, just to test?
    Oct 2011
    this is the opposite of the sudden acceleration. ito naman stuck acceleration. lol. maybe problem with the ecu module if your monty won't accelerate further.
    Check your manual if you can try resetting the transmission.
    Just my 2 cents.
    iam3739.com
    Jul 2004
    whoa, a case of SUA - Stuck Unintentional Acceleration
    Pano pong stuck? Naka invecs mode po ba kayo that time?
    Apr 2012
    TO: 111prez
    yes sir I tried using triptronic mode kaso hindi ng change gear pero nung pinunta ko sa neutral and tried triptronic again naging ok naman sir.
    Apr 2012
    TO: Drey
    is it possible to reset the transmission sir? sorry sir just a newbie
    Apr 2012
    yes sir I was using triptronic that time..
    Apr 2012
    haha, oo nga sir eh pero atleast hindi sudden acceleration kasi mas delicado naman un..
    May 2010
    Quote Originally Posted by st. pierre View Post
    i won't shift talaga. You're in manual/invecs mode pala eh.
    Apr 2012
    Quote Originally Posted by SiRbossR View Post
    Bakit po hindi magshishift sir? Salamat po.
    Jul 2004
    it will not shift automatically because you are in manual mode. it will downshift but it will not upshift on its own
    if you want to shift automatically, then you have to move the lever back to D
    so nothing is wrong with the tranny except this?
    Oct 2011
    mukhang driver error lang...
    Jul 2004
    hmmm, baka unintentional oversight lang
    that is why it is always best to read the owners manual
    not all vehicles are created alike
    The Jazz CVT has a reset ritual.
    I am not actually sure if the Montero has.
    Try unplugging the battery for a few minutes and reconnecting it again. See if that solves the problem.
    iam3739.com
    hindi rin ba siya mag shift automatically once you reach the redline pag naka tiptronic? ganon kasi kia/hyundai pag naka manual mode automatic shift to next gear pag na reach yung redline.
    Jul 2004
    Quote Originally Posted by valskie01 View Post
    i have never redlined it yet so i would not know
    wala ba sa owners manual?
    Jan 2011
    I have also experienced this a few times when driving on mountainous roads. If I leave the gear in Drive while negotiating long, steep, winding roads, this has a tendency to happen. However, if you stop or at least slow down, it will go back to normal.
    To avoid this, shift to sports mode or use the paddle shifter and select gears manually BEFORE negotiating mountainous roads. If you continue to use "D", and this happens, you will not be able to shift anymore even if you shift to sports mode. You would need to slow down or stop to correct this issue once it is present already. I never experienced this again since I started using the paddle shifter BEFORE the steep inclines. By the way, this does not happen on short inclined roads.
    The invecs tranny of the monty is a learning tranny which adjusts to the driving behavior of the driver. You would notice this when you change your driving pattern and then shifting points will change after driving it for a while. When we are driving on mountainous roads, shifting points are greatly changed. I think the tranny just learns a bit slow as to realize that we are already on a flat surface. Just give it a bit more time.
    This is just my own personal opinion and honestly, i dont know either if it is considered normal. A few members of MSCP has also encountered this issue but so far, no escalated damage or issue has been reported. It seems to be just a temporary issue which corrects on its own.
Monterosport A/T problem??
