Results 1 to 4 of 4
November 11th, 2009 06:39 AM #1
Magandang umaga po sa mga tsikoteers, patulong naman mga transmission masters, my unit is a 2000 hilander xtrm. lately lang may naririning akong kakaibang ingay galing sa ilalim, pag nag e engine break ako, lalo na at 1st gear, and medyo humihina ang tunog at 2nd gear. note that this happens only while engine breaking. mawawala sya when i press the acccelarator. the noise seems like a muted metallic "kkrrrrrriiiing" . napansin ko ito after na abutan ako ng knee-high na baha sa kalsada. the engine was running all the time naman until nakatawid ako from the baha. may bumigay kaya sa tranny, or sa clutch system? waiting for your replies, maraming salamat po.
November 11th, 2009 08:18 AM #2
torogikid,
while the vehicle is in motion, you do not shift to first gear specially on engine braking or your engine and/or transmission will break. your first gear and your reverse gear are not synchronized nor do they have synchromesh capability. the vehicle shall be completely stopped before you shift to first gear or the reverse gear.
jick
- Apr 2009
- 544
November 13th, 2009 12:09 PM #4sabi mo nabaha ka, how deep? babad ba ang transmission?
anyway kung ako ikaw kasi sa akin nabaha din, change mo muna transmission oil and gear oil, then pakinggan mo uli. kung meron pa rin possible is the clutch system. puedeng yung release bearing etc..
high idle RPM at engine start
