Results 1 to 10 of 16
November 26th, 2012 10:20 PM #1
kapapalit lang ng secondary master assembly (clutch) ng L300 namin, pero after only 550kms... nag leak na. sabi ng suking mekaniko kailangan na daw palitan ang clutch disk, pressure plate and release bearing. dahil mataas daw yung clutch dati, nag adjust na daw siya at sagad na ito. maski magpalit kami ng secondory master hindi rin daw tatagal. tama ba?
is it possible na hindi sira yung tatlo? or isa lang sa tatlo ang sira?
do you have any idea how much will it cost me for the 3 items? what specific brand do you recommend?
thanks.Last edited by trucker111; November 26th, 2012 at 10:23 PM.
- Apr 2009
- 429
November 26th, 2012 10:30 PM #2basta hindi pa nagsla-slide clutch mo hindi pa palitin ang pressure plate, clutch disc, release and pilot bearing. You dont need to replace these mentioned parts if your problem is only leakage. Leaking clutch hydraulics usually present hard shifting and not sliding clutch. Cheap replacement hydraulic clutch parts usually leak pretty easily. Is your original clutch slave not salvageable? if not place a good brand of clutch slave...
November 26th, 2012 10:35 PM #3
FIC brand ba nakuha mo? Just make sure na original siya. Sa amin ilan beses na din nasira. Pero hindi naman 550km. Usually umaabot ng 20k kms bago masira. And alam na ng driver namin pano mag DIY replace
November 26th, 2012 11:37 PM #4
November 26th, 2012 11:41 PM #5
November 26th, 2012 11:44 PM #6
i want to make sure na hindi ako ginogoyo ng mekaniko.
but 550km.... there must be something wrong.
November 27th, 2012 10:18 AM #7
SIR maliban sa mechanico mo yung pinagkakabitan ng secondary clutch baka po ang dapat palitan...
or sir try nyo ulit palitan ang secondary clutch baka may factory defect ang nakuha mo... dalawa naman po yung goma nun dba? pag tumagas sa isa meron pang isa... at mura lang naman yan... nasa 150php lang more or less....
November 27th, 2012 10:28 AM #8
November 27th, 2012 02:10 PM #9
November 27th, 2012 02:52 PM #10
etc.etc.....maaari din na wala sa tama ang alignment ng pushrod ng clutch pedal. nagkakaron ng lateral movement ang cylinder ika nga. other than defective materials baka incorrect din ang installation.
Latest mileage:
