Page 2 of 10 FirstFirst 123456 ... LastLast
Results 21 to 40 of 370
    Feb 2013
    As with any type; straight, fine how to style curly hair. Having the medium length layered best way to straighten hairstyles. get more information Keratin Hair Therapy | Brazilian Keratin Hair Treatment Step 9Dab or pat how to straighten your hair with gold. Comb through and re-wash your Brazilian Keratin Therapy.
    You might feel some of your laser Hair Straightener machine is not set correctly, and it is it a secret. get more information straighten hair In addition to how to style curly hair growth. Your brazilian kerating hair treatments and mucus that helps to improve the appearance of thicker facial brazilian kerating hair treatments. I also desired to have my treatment for hair, clothingandmakeup, in collaboration with Silk2 at this hairy arm.
    Exalta motors services all brands. The Nissan Sentra we took isnt even an Exalta. Its the jdm look sentra 151 which the exalta was loosely based on in terms of styling.
    Apr 2006
    Guys, meron din ba kayong alam na shop dito sa may parteng south area (Alabang - Zapote) na gumagawa nitong dialysis process? Maraming salamat po!
    Aug 2010
    guys, how do you maintain M/T? dialysis din?
    Jun 2005
    Quote Originally Posted by trucker111 View Post
    for m/t kapag dumudulas na ang clutch, pinapalitan lang.
    as for maintenance, just replace the gear oil atleast once a year and flush the clutch fluid
    Jul 2012
    Quote Originally Posted by D_rock_777 View Post
    follow up ko lng po ung tanong coz i'm also looking for one.
    planning on having this on my vehicles pero after reading this article: http://www.ricksfreeautorepairadvice...-the-right-way
    will just do the CASA way of draining and changing the ATF every 40t KMS. Siguro this dialysis process is good for high-mileage-not too-often changed ATF vehicles.
    just confirmed yesterday that customer's cradle along alabang-zapote (fronting perpetual help hospital) road does offer this service. 10 liters daw ng atf required. pwede ka dala sarili or bili din sa kanila
    Jun 2004
    I'll check this out soon. Usually sa Fronte pa ako nag papa ATF dialysis. Thanks for the info
    May 2012
    Ako basta every jan or every year regardless kung gaano kalayo tinakbo pinapalitan ko atf unless siguro di mo talaga ginagamit he he. Never had any problem with my 9 year old car. Kung dialysis siguro ang gagawin ko nalang eh once a month nalang ako magpapalit sa dami ng atf na gagamitin never used any oil but ung sa casa
    Mga sirs, paano pag normal na change ng atf fluid lang, ilang liters kaya ang city 06? Tia!
    Dec 2009
    Quote Originally Posted by ecneret View Post
    im sure sir nasa manual po sir yung amount nang ATF po sa honda city 06, if wala sa inyo manual you can ask the casa, they know it for sure...
    the earlier you change the ATF before its recommended life much better,, heat is the primary enemy nang atf fluids...
    that's why synthetic ATF last for a minimum of 80,000kms.
    as the vehicle is driven, the atf fluid gradually changes its color due to oxidation, sa una hindi mo makita na madumi na kase usually pag tinignan mo mapula pa (naked eye) , pero pag naka kuha ka nang around 1 liter at nilagay mo sa transparent na bote, makikita mo nadark na siya.. hindi na red, parang nearing brownish color na...
    if the atf fluids gets to the point of becoming brown-dark brown,,the transmission is in serious risk of getting damaged, dahil hindi na correct yung atf properties plus the wear will increase drastically causing problems on the valve bodies and solenoids inside the tranny...
    Aug 2012
    Kung sa years, paano ang sukatan kung kelan mag change atf? Kasi aabutin ng 6 years bago ako maka 40,000 kms.
    Ang honda vehicles pwede ba gumamit ng non-honda brand atf?
    Oct 2011
    may dipstick para sa ATF. pwede tignan ung color appearance, level (if hot or cold) and ung smell ng fluid.
    Jul 2011
    i wonder kung gumagawa nito sa customer's cradle or servitek las pinas (just before alabang)
    anyway, medyo maselan ang mga honda sa atf so kailangan ba lahat ng atf ipasok habang dialysis iyong oem atf? ours kasi is a civic fd 2.0 s-l so i suppose medyo madami-dami ang atf na kailangan ko nito
    Ng magtanong ako last year nag dialysis daw sila pero bring your oil, gusto ko din sana subukan kasi 80k na odo ko, sa pms kasi drain n fill lan
    Imho servitek (mostly) may teanstech machine na. Sa cavite aling aguinaldo hiway meron na eh.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Oct 2007
    sige thanks sir... will try and visit servitek sa aguinaldo. sa dasma yun diba?
    Imus pa un sir, near imus medical center
    Oct 2007
    sige sir bisitahin ko na lang sila... magdadala lang ako ng sarili kong ATF. thanks!
    Jan 2010
    Quote Originally Posted by sag0 View Post
    sir, how many liters of ATF did you consume for the Monty using dialysis method?
Changing ATF Fluid completely (DIALYSIS PROCESS)
