Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 440
    Feb 2010
    Quote Originally Posted by francisacharon View Post
    sir nabasa ko lng sa thread, san po mahahanap shop nila Sir Diesel Dude's Central Diesel? may problema kasi lj78 ko mukang tranny problem and black smoke.
    Sir Central Diesel is just along Quezon Avenue..
    Feb 2010
    Oct 2008
    Currently looking for a place to handle an immobile Hyundai Starex's busted transmission. Any recommendations? Thanks in advance.
    Jul 2014
    Sir try mo tawagan si mr jun.. gear specialist iyan. eto number sir 09176984278. Pakisabi na lng ako nagrecomend.
    Oct 2008
    Thanks for the recommendation!
    Jan 2016
    Good day po. Looking for Nissan teranno transmission especialist nearby Binan, Laguna. . Need to fix. Walang Hawak, nag overheat ang atf at tumitirik makina.... Please mssg me 09194135391.... No calls, I'm on roaming..
    Thanks po..
    Jun 2016
    i have a 2000 model honda civic vtec 3 matic transmission, when the tranny failed i had it done at banawe by Dodong at cardiz st., specialty nila transmission, they went to our place early morning, palit ng internals using repair kit, afternoon around 430pm they came back to put the fixed tranny back into the car, cost is 25k, medyo mahal pero at least wala masyado downtime
    dodong 0923808 8076
    Mar 2016
    Hi! Looking for an AT repair specialist in Makati for our 1989 Nissan Pathfinder. Engine oil is leaking and the seal/gasket seems to need replacement. Would really appreciate the help!
    Called Speedyfix in San Juan today and Migs quoted me 5k sa labor palang pagbaba ng tranny. Ganito po ba talaga yung price? But better parin sana kung meron shop na reliable sa Makati para malapit lang and matutukan ko yung kotse.
    Thank you!
    Mar 2016
    need po help guys...honda cty typez 2000...ang pinalit na a/t ay kagaya ng sa esi...my problem is ung lagayan nya ng trany support..sa auto ko ay sa front at ung sa esi is sa lower left... pero meron din sya hole sa front ang problema ay maliit ang butas at walang thread...ang tanong ko po ay posible ba or pwede ba idrill un at palakihin ang butas then lagyan ng thread which is size is 14....at saan pwede ipagawa kaya?..salamat po
    Mar 2016
    Quote Originally Posted by allan1088 View Post
    any idea mga sir
    Apr 2010
    Help naman: I don't know kung sa Engine or sa Automatic Transmission ang may problema sa kotse ko (Mazda 323). nanginginig yung makina niya on idle...then when shifting to D, may pagkawild yung acceleration niya sa unang gear (pero kapag nasa second gear onwards, smooth na; even sa reverse [R] OK naman yung takbo).
    Mar 2004
    Have your engine and transmission mounts checked. Replace them with original parts, don't use replacements.
    Oct 2013
    For AT troubles, maayos kausap to si Macmac. Dating tao ni Leonard Bulaong. Humiwalay na. Mejo magulo kausap si Bulaong e. and laging puno ung lugar nia sa Cardiz.
    Either maraming customer o madami di naayos.
    09198770031 -MacMac of Banawe.
    Ang negative, wala siyang sariling shop.
    Pwedeng home service. Bili ka na lang ng parts kay Fullness.
    Sent from my SM-J700F using Tsikot Forums mobile app
    sa south side recommended ko si d & r fast auto repair service sa sucat ave, paranaque
    former honda casa tech ang bosing doon pero they do all kinds of makes & models. minamani na nila actually mga tranny overhauling and the like. nakasabayan ko dati aside from honda vehicles, mga hyundai at isang ford f150. nagulat nga ako pag visit ko last week para palit atf aba'y meron na silang flat bed truck car hauler. business must be doing so well and i'm happy for danny, the owner of the shop
    i'm going back there in the near future to have our monty's atf filter replaced naman
    Aug 2016
    I need some advice po.
    Yung Auto Tranny po ng Space Wagon ko kakapalit lang po (laman loob that is). Okay naman shifting from 1st gear to 3rd gear (smooth shifting) pero pag naka O/D ON nagrerelease yung gears pag O/D of kumakagat ulit, so lagi po ako naka O/D OFF kahit highway drive. Also pag mejo matagal na siya tumatakbo yung downshift niya negjejerk pero pag kakaandar or pag di pa masyado malayo natatakbo okay lang yung downshift minsan naman okay siya. Anu po kaya possible problem?
    P.S. Surplus po yung ginamit na replacement ng tranny pero yung housing yung original na nakakabit. After ng replacement di pa ako nagpapalit ng ATF, yun parin yung ikinarga ng gumawa po.
    Thanks sa mga magrereply. :-) God Bless.
    Jun 2005
    Quote Originally Posted by Prince.Mickey View Post
    Nye! Nagpalit ka na ng transmission pero di ka pa nagpalit ng ATF? Maling mali boss.
    Para kang naligo pero sinuot mo pa din yung maduming brief.
    Dapat replace fluid ka dapat. Pinaka basic yan kung may problem ang AT mo...
    Aug 2016
    Quote Originally Posted by sirkosero View Post
    Thanks for the response sir, what I meant po is after ng replacement ng tranny bagong ATF yung ginamit, may nabasa kasi ako dito sa thread na need palitan after 1 week yung ATF kasi may metal shavings daw pag bago yung tranny so kailangan daw po palitan after 1 week... tama po ba? :-)
    Jan 2012
    Quote Originally Posted by misterioman View Post
    maayos nga kausap at gumawa si macmac. yung mga kasama niya marunong rin; galing yata sila lahat kay bulaong, tapos humiwalay na.
    puwede rin silang home service, lalo na kung hindi na umaandar yung auto. pero dinayo ko na sila kasi malapit lang sila sa banawe. at least madali lang maghanap ng piyesa.
    ang pinagawa ko pala, transmission overhaul lang nung una, pero nung binaklas na, pati pang-ilalim pinatira ko na.
    auto ko 2003 nissan exalta grandeur gs
    Feb 2017
    Quote Originally Posted by sergeant pepper View Post
    mga master, problema ko rin po crosswind XTO mdl '02 ko. nawala ang reverse pero sa D ok naman. malakas pa umahon sa bundok. updated po ba cp number ni MacMac ng Banawe? HELP po pls.
    Mar 2017
    ano na po number ni macmac? may problem din ako sa transmission ng avanza 2007. havent use it for a year.. nabili ko second hand
Automatic Transmission Specialist
