Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 440
    sir otep,thanks sir. if Alex Bulaong wont be doing anything else to make things right then i will post this sa goon squad..
    Aug 2010
    Quote Originally Posted by cocoy View Post
    Hi cocoy, Im the first and one of the loyal customers of Bulaong Shop and had my vehicle serviced by them yesterday. Leonard is no t around when I came there. I hope that they can fix the problem of your car.
    Quote Originally Posted by wrathbu View Post
    well where still waiting if they will ever come back to work on it. palagi kasi cnasabi nila nga daw ang electrician that can take a look at the wiring and ECU.. tanong ko lang kasi. bakit binaba agad nila ang transmission? paano kaya if wala naman pala sira ang transmission.. sa wiring lang pala.. yung ang ayaw ko dun.. if you read my post.. i think you will understand why i feel the way i do..
    kausap ko lang c bulaong.. yung electrician parin ang excuse nila. nga di pa daw available.. dapat kasi una nila na trouble shoot ang wiring and ECU before ibaba ang transmission.. sana isauli nalang nila ang pera namin.. para tapos na.. 2 lingo na kasi ang pag hintay namin..
    Aug 2010
    cocoy, pwede ba dalhin yung big horn sa shop ni bulaong? baka mas mabilis matapos ang trabaho pag dun ginawa ang sasakyan mo.
    dito nga kami sa silang cavite sir.. kaya home service ang agreement namin dun.. kasi nga hindi na nag change gear ang transmission..
    feel ko talaga nag kamali kami sa pag patronize kai Bulaong..
    May 2012
    mga sir may problem din ako sa automatic transmission ko, ford escape 2008 model ung akin. minsan kumakagat ung reverse nya minsan neutral and minsan naman neutral nya nag didrive.. any advise, may naka experience na dn ba ng same problem ko and baka may marerefer kyong mekaniko?! thanks
    just to update on our big horn transmission problem.. we eventually went to Alex Bulaong shop.. and talked to him. to asked if they are done with what they did with the bighorn transmission.. they told us to bring the car to the shop.. so they came to get the bighorn.. and just manually shifted gears to make it to their shop.. at the shop the electrician took a look at it and said there was a wiring problem..
    the only problem then, it would cost us another 12k.. on top of the 25k that we had fully paid already.. so we decided to just pull out the unit.. but before we could get to the shop. they called and said that the big horn was working already. ok na daw ang pag change gear.. we called them again and said we didnt say that they should work on it..
    when we got there we talked to alex and his son.. we told them the deal was they fix the transmission to working order. they failed to do that in the first place. then now they wanted us to pay 12k for the electrician. i really gave them a piece of my mind. eventually they said kami nalang daw bahala how much we will pay.
    in the end i gave them P1500 para matapos na.. in my mind kasi i dont think 12k is right to pay just for soldiering a broken wire.. i say that it was only a broken wire somewhere. because they didnt argue with that. if they changed the ECU i dont think they would just say "cge kayo na bahala kung anu bigay nyo.".
    this got me thinking.i think they just really tried to make a fool out of me. they should have really trouble shoot first before taking the transmission apart.. i think there was nothing wrong with the transmission in the first place.. shifting gears was the only problem. which was probably because of a broken wire, leading to the speed sensor. kasi ang lakas pa naman mag arangkada ang sakyan.. you could still make it wheel spin on gravel.. based on that i dont think the clutch was sliding.
    im not an expert on A/T but i think i would know if the clutch was sliding.. and based on their non reaction when i told Alex that, it confirmed what i had thought.. so yun we paid P1500.. and drove the big horn back. never ever to take it back to bulaong...
    this is my experience with ALEX BUlAONG.. but naman they still manange to make our bighorn change gears.. if not ALEX BULAY-OG, would be his new name on my mind..
    so just keep an open mind guys if you want to get your transmsssion looked at by alex or any other AT specialist. canvas ka muna sa iba until you find someone worth trusting..
    through out this ordeal, of having to wait and calling bulaong.. i talked to other AT specialist.. and most of them said mali daw talalga ang ginawa nila bulaong. they said removing the transmission should have been the last thing done in that kind of problem.
    well im more informed now..
    Jun 2012
    Any auto tranny specialist? Glxi lancer 93, problem is shift shock, pad nag D ako parang isang gear lng ang gumagana, tia more power tsikot. Im from valenzuela
    Nov 2003
    Nag back-read ako from page 1. Sa simula panay good reviews kay Bulaong, kaya papagawa sana ako sa kanya. Pero pag dating sa bandang huling page may bad review na, so nagdadalawang isip ako ngayon.
    Sa thread na 'to mostly Bulaong ang mga naka post na experience. Sa Baltak may naka try na ba?
    Jun 2012
    Quote Originally Posted by nic View Post
    Oo nga boss hirap mag decide, help mga gurus!!!
    Jun 2012
    Just to help lang po, if you have any transmission problems, check the link
    **************/index.php/view+classifieds/id/4248868/AUTOMATIC+TRANSMISSION+SPECIALIST+/+REPAIR
    as consumers mas ok ang maraming choices... to help out na din if you have questions just call or text, i will be more than glad to answer them to help you out ^_^...AUTOMATIC TRANSMISSION SPECIALIST
    Jun 2012
    Quote Originally Posted by transmissionboy View Post
    AUTOMATIC TRANSMISSION SPECIALIST - Engine Repairs and Service - Tsikot.Net Directory of Auto Shops and Services
    e2 po yung link, hope i can help you with your questions, glad to help ^_^
    Jun 2012
    Ano pinagawa mo sir at ano oto mo and magkano
    Jul 2012
    Sirs, problem with at toyots camry 1988..but with same engine as tyota corona and first gen rav4. Sa inclined position or pag hanging..i need to use the hand break para di ako umatras..dati nman steady lng sya pag nkahanging ako.hasle for an at di ba. Nd pag malamig ung car, sa reverse or primera, parang nag i-slide sya,parang bumabalik sa neutral.any same xperience?nd san ko kya pde ipagawa.help pls.tnx
    Aug 2009
    good eveng, sir. saan ba pwde pagawa ng transmission? ung trusted and reliable? not expensive?
    my problem in the transmission. pag nakadrive tapos patakbuhin mo. tagal sya mag shift from 1st to 2nd gear. aabot pa 3000 rpm bago mag shift. pero mag init na ung makina. ok naman ung shifting. yun lang kung malamig pa at bago mag start. tagal mag shift at mahirap aakyat ng uphill (dahil sa shifting) pls help. thank you
    Jun 2010
    Quote Originally Posted by baby_scar View Post
    normal yan sa automatic transmission, kung malamig p at bgong start lng makina then uphill agad ang daan, hindi talaga magshift yan ng 2nd or 3rd gear, kumbaga walang salida...pero sabi mo n kelangan maabot muna yon 3000rpm bgo magshift, may problema talaga, nag-slide yon transmission...malayo kc difference ng auto at manual regarding acceleration, kung bgo start ang auto tranny n sasakyan, kahit itodo mo tapak sa gas, di yan magwawala , di katulad ng manual, pagbitaw m ng clutch, sibad agad..
    try to observation n bgo start ang sasakyan, dahan dahan lng to the max yon tapak, maramdaman mo kung nagsisihift talaga or hindi....saka refer to the manual, nakalagay doon kung ano rpm bgo magshift ang tranny....one more thing, like on my case n parang matagal magshift ang gear, check mo yon lever, be sure you will hear/feel click sound when from P to D or wherever, kc noon una, parang yan din problem ko, tagal magshift, then natuklasan ko n parang di masyado nakaengage yon transmission...(AT XUV Crosswind yon ride ko)
    May 2009
    swift a/t 2007 owner here.
    1st problem sa tranny if wot 1st gear indi sya nagshift to 2nd gear.
    2nd problem sobrang lakas ng shift shock pag D ang gamit ko but pag 3 normal naman.
    3rd problem 5 to 6km/ltr lang ako.
    san kaya pwede magpacheck?
    tia guys
    Quote Originally Posted by lukscudkil View Post
    tia guys
    when was the last time you changed your tranny fluid?
    san din location mo?
    Aug 2012
    Sabi sakin ng SA ko sa toyota nag wwarm up daw yung ATF kaya kapag bagong start matagal mag shift from 1st to 2nd. Medyo hirap sa umpisa ng andar then after a while normal na.
Automatic Transmission Specialist
