Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Transmission Talk Thread, Automatic Transmission Specialist in The Workshop; @zephyr08 same problem tyo sa tranny. I called mr. Bulaong kagabi. Sabi nya change atf and filter gagawin nya worth ...
Page 10 of 18 FirstFirst ... 67891011121314 ... LastLast
Results 91 to 100 of 172
Like Tree1Likes
Thread: Automatic Transmission Specialist
  1. #91
    Join Date
    Sep 2011
    Default Re: Automatic Transmission Specialist
    @zephyr08 same problem tyo sa tranny. I called mr. Bulaong kagabi. Sabi nya change atf and filter gagawin nya worth 4k. Galant '88 car ko. Gusto ko itry kesa palit tranny or rebuild, sana makapunta ako this weekend.
  2. #92
    Join Date
    Quote Originally Posted by jaimeframos80 View Post
    Sir may dialysis machine po ba sina Mr. Bulaong? Mas maganda kasi un, masisimot at ma-fflush ung A/T. At kung mag papalit narin kayo ng filters, mag palit narin kayo ng seals. Alam ko kasi yung filter nasa loob yun ng A/T kaya bubuksan yung pan para makuha ung filters.
    Mag back read kayo sir. May post dito na kahit maganda pag kakasara tumatagas parin yung A/T fluid dahil luma na at marupok na yung seals. Just my .02 cents
    Paki balitaan nalang ako kung mawawala ung shift delay ng 1 sec from P or N -> D. Good luck!
  3. #93
    Join Date
    Thumbs up for AM Bulaong. It wasn't a perfect experience but I'm happy.
    Went there Thursday 8:30 AM. Leonard took the car on a test drive. I just came from Makati so the tranny was warmed up and not acting up that much. Leonard however noticed delays between shifts. He recommended replacing the tranny.
    Tranny was taken down and the new one fitted by lunch time. Would have been go for a test drive already but the radiator (thankfully) chose that exact same day to break the top tank so I waited for 3 more hours and had a tanso top tank fabricated.
    Finally finished 5PM and drove to Makati. Shifts were ok with a slight intermittent delay engaging 3rd gear. A lot better than my old unit though. However when I reached Greenbelt 1 parking the tranny was sliding like hell and had a hard time reaching the 2nd floor. Got myself a parking space and got down to the sight of ATF all over the floor. It was so bad the roving guard called my attention thinking that I ran over somebody. Called Leonard up and he apologized for the goof. He told me to refill with ATF and bring the car back in the next day. Walked to SM, got 4 liters of ATF, a section of hose, and a watering can (funnels out of stock), refilled with 2 liters ATF, waited til 9PM to avoid traffic, and drove nervously all the way back to San Juan.
    Refilled with 1 liter ATF on Friday and drove to Banawe early morning. The diagnosis was a busted axle shaft seal and a minor leak around the oil pan. They tried a surplus shaft seal but after another leak test it still leaked. A new shaft seal finally solved the issue. Lesson learned: insist on having the seals replaced on a surplus tranny. Drove home after lunch and checked for leaks. Garage floor was clean. Drove to the office and checked again for leaks. Nada. Good. I'll be back in a month for filter cleaning and ATF change.
    AM Bulaong is a father and son run shop (with the occasional Orange County Choppers dialogue thrown in every now and then). Dad takes care of pulling apart and reassembling trannies. He makes reassembling a pile of spacers, bearings, solenoids and clutches look easy. When I was there they had a 2nd gen RAV4, a 2006 CVT City, a Suzuki Esteem, and a fellow Tsikoteer's Revo all with tranny problems. Another customer brought in a 2004 Civic transmission that was recently overhauled. When they opened it up the ATF had the look and consistency of wet cement. Needless to say it had to be replaced.
    Deciding between repairing and replacing a transmission is a case to case basis. The usual ATF repair kit contains just the clutch discs and oil seals. If it's a sliding tranny, burnt ATF, or leaking seals then an overhaul is recommended. However a tranny also has solenoids and valves that will break down. When that happens replacing the whole tranny is sometimes easier and cheaper than just replacing the bad part.
    Overall verdict: Recommended
    They're easy to talk with, they work relatively fast, and they're conscious of customer satisfaction knowing that they live on referrals and that online forums will make or break them.
    Sir jaimeframos80 eto po yung sinasabi kong post.
  4. #94
    Join Date
    Sep 2011
    @zephyr08 salamat sir, balitaan kita.
  5. #95
    Join Date
    Apr 2008
    Good Eve, check out this website and give these guys a call, maybe they can help you out, had the same problem and went to honda cavite, one of the service advisors referred me to these people, hope you get your car fixed, God Bless
    AUTOMATIC TRANSMISSION SPECIALIST / REPAIR Philippines - 3486790
  6. #96
    Join Date
    Nov 2004
    Location
    Paranaque
    Guys pa recommend naman ng transmission specialist preferably located south paranaque area.
    Mukhang kailangan ko mag papalit ng solenoid (altis 2006 1.6g)
    Gaano ba katagal mag papalit nito.
    Any contacts if possible and kung bukas sa Sunday
    Thanks
  7. #97
    Tsikot Member dretch88's Avatar
    Join Date
    Location
    Binondo
    guys, any feedback kay bulaong kpg manual tranny na ang pinaguusapan?
  8. #98
    Join Date
    May 2011
    i have this problem on my 03 honda crv real time 4x4,when i press the gas pedal hard enough from stand still,it feels like sliding at first then engages,but theres no problem when you accelerate slowly,shifts are fine.
  9. #99
    Join Date
    Sep 2011
    Quote Originally Posted by batok View Post
    I agree with you. I purchased diagnostic tools OB2 to check the real problem with my Mitsubishi eclipse 3g 2003. My wife driving it every time she shift from P to R she felt the car shake from front to back & if she put in D the car run as normal 1st gear but ddn't shift to 2nd,3rd or 4th gear & lack of power. Currently i'm outside phil so i can't really know the problem & share to you guys. But as soon i go back home this is my proj to play this Auto Trany trubleshooting.
    hi sir singit lang po ganyan din po ung honda 1999 vti ko ang engine b18c, ayaw po magshift sa 2nd gear tapos bigla nalang po hindi gumana ung speed sensor, bumili po ako ng sensor kaso ayaw parin po gumana, naayos n po b ung car nyo sir? salamat po
  10. #100
    Join Date
    Sep 2011
    Taga batangas kc me pina check ko sa car electrical sa amin.
    My car when my wife do from P to R nag jejerk ng malakas and after running already ayaw po ma shift. Kala ko transmission na yun ang sabi ng shop karamihan. I have OB2 scanner lumalabas sa scan ay solinoid so pinabaklas ko at nag check ng solinoid. pero ok naman kaya pala yun relay ayaw mag close kahit na ang PCM bag send na ng signal sa relay kaya ayaw mag shift try mo palitan ang relay nasa 350 lang yan. Yun lang po problema ng car ko enabot din me ng mga 6k including change ATF Aat solinoid check. hayyyyy pero oveall happy me ksa palit tranny.
    sir singit lang po ung car nyo po ba from 1st gear ayaw po magshift sa 2nd gear un po kc poblema ko s automatic tranny ko, d ko na po alam gagawin ko tagal ko na po hindi nagagamit, salamat po
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
