Results 271 to 280 of 439
- Jul 2014
- 162
November 16th, 2014 07:42 PM #271U440E ba gear mo 4 speed? Pressure/ TCC solenoid..
Tsikot Mobile App
- Jun 2010
- 12
November 16th, 2014 08:06 PM #2725 days ago pala nahulugan ng coins ng baby ko yung shift stick lumusot dya sa cover ng shifter. I already informed the mechanuc about it. Pero sabe nya wala daw kaso yun kase chineck niya yung shifter cable hindi naman putol. Nakita ko naman pag sinishift gumagalaw yung shifter sa engine. Wala kya nadamage yung coin sa loob ng shifter?
- Jul 2014
- 162
November 16th, 2014 08:09 PM #273Wla dun iyon sir... Maganda makita v.body at mabuksan
Tsikot Mobile App
- Jun 2010
- 12
November 16th, 2014 08:42 PM #274
- Jun 2010
- 12
November 16th, 2014 08:51 PM #275Nagtataka lang ako sir kase prior to this wala naman siya symptoms ng failing tranny. In fact maayos pa sya humatak nsgrerespond naman agad pa siniishift ko. Madalas ako sa Antipolo proper via Marcos hiway dapat napapansin ko kung may problema lalo na matarik sa alpadi. Nung nadrain yung ATF ko maayos pa naman hindi sunog tsaka malinis pa naman filter.
- Jun 2010
- 12
November 16th, 2014 09:07 PM #276Tsaka mga paps sabe ng mechanic ko although hindi naman siya A/T transmission specialist based on his experience pag failing tranny at least magloloko muna tsaka at least may isa or dalawa gears pa rin na gumagana. Yun saken daw kase bigla na lang hindi gumagana lahat ng gears. basta bigla na lang huminto.
- Jun 2010
- 12
November 17th, 2014 05:27 PM #277Mga sir if ever bibili ako surplus tranny ng altis ko sa banawe paano ko malalaman kung ok yung tranny na nabili ko. Pwede ba ipressure test ko muna bago bilhin. Tsaka yung warranty usually gaano katagal. May nakita rin ako sa olx taga valenzuela nagbbenta ng surplus na toyota engines, may 3zz-fe tranny sya 23k, ok ho ba presyo nun? Thank u mga sir.
- Jun 2010
- 12
November 22nd, 2014 02:38 AM #278Good pm po mga sir. Nagpalit na ho ako ng automatic tranny ng 03 Altis ko japan surplus ho pinalit. Napansin ko lang nagloloko rev niya. Parang nagoloko throttle valve niya. Sir pagnagpalit ba ng automatic transmission lalo na pag japan surplus kelangan ba ireset yung ecu ko para umayos siya?
- Jun 2012
- 35
November 28th, 2014 06:08 PM #279
- Jun 2012
- 35
November 28th, 2014 06:14 PM #280sir ilang palit npo ako ng atf, nag lagay ng lucas medyo humina lng kaldag, then dialisys wla p din, lagay ng ibang type ng lubricant from us daw tranny fix ala p din..pero pag umaga pag alis garahe ok shift, tapos after 10mins yun lalabas na kaldag. pero pag 1st gear tapak gas then bitaw ok shift ng second gear. tatanong muna po ako bgo palit surplus or rebuild
Monk-owned R53
