Results 211 to 220 of 439
July 28th, 2014 12:12 PM #211
^ better yet pa-scan mo na. that way hindi na kailangan mag trial and error
sa southside madami nanaman repair shop na equipped na niyan (nabasa ko tiga cavite ka kasi bro). one is d&r fast repair along sucat ave and the other shop i know of who has an obd2 scanner in las pinas is customer's cradle along the alabang-zapote road. or pwede din sa casa ka na magpatingin sice libre naman ata iyan
July 28th, 2014 12:58 PM #212
Sir nangyari na din yan sa akin nag bblink ang o/d off at speedometer ko hindi rin gumana. Ang ginawa lang sir pinalitan lang ang speedometer sensor at nag ok na. Pero kung gumana nman speedometer mo hintayin natin mga experts dito baka sa wiring lang yan.
Posted via Tsikot Mobile App
- Jul 2014
- 5
- Jul 2014
- 162
July 29th, 2014 05:51 AM #214Pwede din sir sa VSS/T.range.. Pero check nyo din ang ATF baka sunog o madumi na.. Common jn pag sunog o madumi ATF my sira ang V.body pwede stock ang switch SL at TCC. Check nyo na din ang Lock up at accumulator.
Tsikot Mobile App
- Jul 2014
- 4
July 31st, 2014 06:02 PM #215Hi Sirs, enlighten me naman po.. I know this has been asked countless times..
pano po pag hindi lang basta sunog yung atf kundi umusok pa yung tranny?
overhaul nba talaga solusyon?
just called bulaong's landline num to inquire about this issue, his diagnosis is overhaul, at P35,000 cost.
medyo madugo daw kasi ford fiesta 2011 model (kahiya kasi halos bago plang, nagiba ko na )
any thoughts will be deeply appreciated
July 31st, 2014 06:35 PM #216
Wow, you really toasted your tranny. Overhaul na nga yan.
The 35K is just an estimate, I am very sure it will be much more expensive once the actual overhaul is being done.
- Jul 2014
- 4
July 31st, 2014 06:52 PM #217^huhuhu.. i have his words, like "yes, 35k lahat lahat na, original parts kasi wala kame surplus nyan"
baka maiyak na ko pag lumagpas pa ng 50k to..
will do some canvassing nlng muna,
salamats sir lows
July 31st, 2014 07:10 PM #218
^ if you're from the south, you can ask for a quote and diagnosis from d & r fast repair along sucat ave (look for danny). may obd2 scanner siya kaya hindi na hit or miss ang pag diagnose niya.
from what i've seen and experienced in his shop, he's pretty good at doing tranny overhauls. at saka madali din siya kausap
hthLast edited by baludoy; July 31st, 2014 at 07:19 PM.
- Jul 2014
- 4
July 31st, 2014 07:40 PM #219based on sa fb nila, mukhang madaming customers
bukas will call their landline, sana ma accomodate naman nila ako.
thanks sir bal
- Jul 2014
- 4
July 31st, 2014 07:44 PM #220based on sa fb nila, mukhang madaming customers
baka super mahal ng singil nila sir?
Xiaomi E-Car
