Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Transmission Talk Thread, Automatic Transmission Problems [Merged] in The Workshop; i had experiencing difficulty on reversing my Honda esi '95 especially when the car is park for long time..10 hrs...hinde ...
Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 89
Thread: Automatic Transmission Problems [Merged]
  1. #1
    Join Date
    Default matic problem
    i had experiencing difficulty on reversing my Honda esi '95 especially when the car is park for long time..10 hrs...hinde agad engage un reverese gear.
    is this normal s matik? need to revultion it for some time before ma engage un gear..
    insan hirap makina bumatak lalo n pg pinatakbo mo agad withopu any warm up..
    hope u can help me guys...
    thanks..
  2. #2
    Tsikot Member Rank 3
    Join Date
    Dec 2002
    Location
    vancouver, canada
    Default Re: matic problem
    check your transmission fluid parang kulang
  3. #3
    Tsikot Member Rank 5 alwayz_yummy's Avatar
    Join Date
    May 2004
    Location
    tabing ilog
    as per experience, ganito, tatapatin na kita: anu makina ng civic mo? and hirap ang hatak ano?to the point na mag-ooverheat na ung makina..
    sad to say, eto pinakabest(kung ok ang fluid level mo, pero amoy sunog, nangangamoy na sunog) and cost efficient solution dyan...
    punta ka sa banawe/evangelista/blumentritt, ipababa mo buong tranny mo, bili ka ng surplus, ipakabit mo...bili ka din ng ATF of the same spec, pero wag ung below 150 pesos, di maganda un, pang a/t flushing lang mga un...at di tatagal...dapat from known imported brands: motul, mobil, castrol..basta imported..mga 4-8 liters yang laman nyan...
    wag ka na magpa-overhaul ng tranny, sayang lang pera mo, palitan mo nalang ng magandang surplus...
    to be sure ok pa ung tranny mabibili mo, dala ka ng dipstick,, amoyin mo ung langis sa loob...kung sunog din ang amoy, iwan mo, kung may-pagka-"sweet-and-sour" ang amoy, kahit di mapula ung langis, maganda na un.. pero kung kulay pula at "sweet-and-sour ang amoy, aba kunin mo na!
    tignan mo din ung sealant and bolt heads, dapat kahit isa walang sign na nabuksan na..
    dala ka ng trusted mong mekaniko...and remember, ang torque converter ay parating kasabay ng buong tranny kung ibabalik...and remember to ask ung nagkabit na bago lagyan ng fluid/ ikabit, i drain lahat ng ma-ddrain na fluid, kasama ung sa ATF sa torque converter, at ung mga nasa cooler(radiator and oil cooler->if any)...ipaalis mo din ung oil pan and filter ng tranny,ha...kung ok pa linisin mo nalang, otherwise palitan mo na din yan,ha?
    hope this helps...sorry to be a bringer of bad news..
    eto marerecomend ko dun:
    ultima surplus haus
    424-f kaliraya street cor banawe st QC
    742-9828
    dito ko nabili tranny ko, at ok naman ung nakuha ko despite the rock bottom price....at kung sila nagkabit, they can give 1 month warranty...tawagan mo nalang din sila kung meron silang stock at magkano...
  4. #4
    Tsikot Member Rank 5 theveed's Avatar
    Join Date
    Location
    Singapore
    Great points by alwayz_yummy... but singit ko lang something that namiss...
    Check the contron cable.
    There's a cable that links between the shifter and the tranny (kung san man yun papunta), pwedeng yun lang may sala.
    Usually kung control cable or shifter bushing ang worn, mas kumakapit pag pataas ang shift (1 to 2, 2 to D, D to N, N to R, R to P) kesa pag pababa (P-R-N-D-2-1)...
    In my case, may bushing lang na nagwear sa shifter mismo kaya may konting "play" yung shifter between gates... nothing to do with the tranny itself.
    My Blog Network JEREMY LIN FAN CLUB[/url] site.
  5. #5
    Join Date
    orir engine dw un engine nun n esi...hinde me lng alam wat spec kind of engine un..pero hinde un vtec...
    last January ng palit me ng oring seal sa maindrive...pati un s filter...
    tumataas n din temp nya lalo n pag akyatan n...i have to check on the fluid quality..i hope n kulang lng ng atf un...mdyo dami ko n gastos dito s car...
    thank you s info nu mga sirs.....
    anybody has a owners manual ng Honda ESI 95...para my reference me...im very new when it comes to car....sana hinde kau magsasawa bigay ng tulong sa mga un needs...
  6. #6
    Join Date
    Location
    Singapore
    Please DO NOT type in SMS format...
  7. #7
    Join Date
    May 2004
    Location
    tabing ilog
    pero mukhang malabo ung mis-aligned cable for lever and the tranny...
    you say nagpalit ng oilseal sa main drive, baka mali ang salpak,so baka worst nasira torque converter mo...
    ang pag check ang atf di tulad ng makina na kailangan 1st thing in the morning, ang atf ay checked by ganito:
    start mo engine, shift ka P-R-N-D-2-1or L-2-D-N-R-P then bunutin mo dipstick, punasan mo, balik mo, tapos tsaka mo palang ma-aaccurately check ung atf level, amoyin mo na din...dapat sa gitna ng L and H level...kung may "cold" and "hot" dapat bumaba sa "cold H and L" then kung mainit na( idling for more than 5-10 minutes) dapat nasa "hot H and L" level...
    ang key is sunog ang amoy, at di mala-"sweet and sour".....
  8. #8
    Tsikot Member Rank 3 ineedmorehp's Avatar
    Join Date
    Location
    On top of her...
    Quote Originally Posted by alwayz_yummy
    ultima surplus haus
    742-9828
    Sir, may mga question lang ako:
    1.) Bakit amoy sunog
    2.) Ano nasusunog? Torque converter?
    3.) Ang shell ATF ba hindi imported? Locally manufactured?
    4.) Tuwing kelan ba dapat nagpapalit ng ATF?
    5.) Tuwing kelan ba dapat nagpapalit ng A/T Tranny (hehe, serious question 'to ha)?
    6.) Bakit wag na pa overhaul ng A/T tranny?
    Sorry ha dami question - ESi '94 btw. Baka yun lang din prob ko kasi hina hatak. Mga tinitignan ko kasing options: mini-me, b16 a/t, and Force ind. (supercharger daw para maliksi).
  9. #9
    Tsikot Member Rank 3 Autobeat's Avatar
    Join Date
    Quote Originally Posted by entoy
    entoy, yup, try muna refill/replace atf fluid. Hopefully ayos pa naman tranny.
    alwayz_yummy, magkano mo nakuha surplus tranny? ESI rin ba yung pinagpalitan mo?
    Quote Originally Posted by ineedmorehp
    ineedmorehp, at least sa Honda, kung walang problema sa tranny, palit siya every 40tkm. Intay natin reply ni alwayz_yummy. Interested rin with his inputs on your questions.
  10. #10
    Join Date
    Location
    Singapore
    I believe local, but shouldn't matter...
    According to manual... Usually every 25-30K, ako annually mura lang naman.[/quote]
    If taken care off, usually AT lasts longer than MT.
    Super duper complex ang hydraulic system ng AT, sobrang tight ang tolerance ng mga gaps and channels sa housing, almost impossible maayos ng tama... Labor palang mahal na, kung sa kasa expect to pay 6 figure just for tranny overhaul... Bili ka nalang buong surplus diba.
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
