Results 1 to 4 of 4
- Sep 2011
- 16
October 7th, 2011 04:06 PM #1Ask ko lang po kung ano ang nagbibigay ng signal sa transmision para magshift ng gear, electrical po ba o ung speed?
October 7th, 2011 04:17 PM #2
my sagot to your tanong:
in the old transmissions, the throttle cable and the governor of the hydraulic shifted automatic trans
in the new transmissions, the throttle sensor, vehicle speed sensor, coolant temperature and the mass airflow sensor or manifold absolute pressure sensor all input to the powertrain control module to command the shift solenoids.
- Jul 2003
- 573
August 28th, 2014 09:46 PM #3Hi Jick,
sa bagong transmission ano ang role ng TR Sensor? Di mag-crank engine kapag di naka 'P' ?
August 29th, 2014 07:13 AM #4
Part of the trans to enable or disable cranking is still the park/neutral switch. Parts that prevent engine cranking include the alarm and anti-theft system
Posted through phlpost.gov.ph
Suzuki JIMNY [merged threads]
