Results 1 to 10 of 10
July 25th, 2014 11:06 AM #1
The car is Honda city 2009, the car will start although kahit ilagay sa D eh hindi nag e engage ang transmission. Tapos nakita ko ito sa likod ng Engine, talaga bang laslas yun? Dahil nung pinatay ko Engine sumisigaw sya. Ano ito at para saan? Thanks.
- Jun 2005
- 3,774
July 25th, 2014 11:37 AM #2bro. alin dyan sa pic ang tinutukoy mo?
Sent from my Thrill 430x using Tapatalk 2
July 25th, 2014 11:54 AM #3
July 25th, 2014 12:39 PM #4
Looks like your HEGO(heated exhaust gas oxygen sensor). If it is, it will have two white wires and two black wires
Posted through phlpost.gov.ph
July 25th, 2014 01:14 PM #5
That 'tank' is the catalytic converter. That round thing with the wires going to it at the top is (as Jick mentioned), an O2 sensor.
It's normal to hear hissing sounds coming from the catalytic converter, especially when the engine has been running for at least several minutes.
As for your transmission, about the only thing you can do for now is to check the ATF fluid level and condition (ie. color and odor). Beyond that, the problem can either be mechanical or electrical (ie. worn clutch packs, bad ATF pump, clogged ATF passageways, bad solenoids, problem with the ECM/PCM, or loose wiring).
July 26th, 2014 07:55 AM #6
Thanks for the input guys, pina tow na. it's a company car. The thing is pinagawa na to dahil sa blinking D. And the company said it cost them 30kh to "fix" the blinking D. 2 weeks pa lang na balik blinking D ulit at di na nage engage yung transmission. Dinala na naman sa Honda. I bet 30k na naman yan fixing nothing. Hay
Posted via Tsikot Mobile App
July 26th, 2014 03:35 PM #7
yung may biyak na sinasabi mo ay heat shield ng catalytic converter. kung cvt ang trans. mo malamang na walang katapusag gastos kung repair lang
- Jul 2009
- 153
July 27th, 2014 10:39 AM #8Yung sakin namamatay engine habang tumatakbo (2007 AT City). After linisin yung ignition coils tsaka palitan ATF (worth P5K) umayos ng 2 days pero bumalik ulit. Nung pinalitan ng AT shift sensor (worth P21K) nag ok na, parang brand new na ulit andar nya.
December 8th, 2014 10:42 PM #9
- 52,731
December 9th, 2014 12:58 AM #10catalytic converter?
i thought those things came in large metal cannisters connected in series to the exhaust system...
Xiaomi E-Car
