Results 1 to 10 of 14
April 18th, 2013 11:46 AM #1
Hello Guys,
Tuwing kelan dapat nag rere-apply ng undercoat? Malapit na mag 1 year yung innova namin and napansin ko me mga na chipped off na sa initial undercoat ng casa(sobrang nipis lang).
Thanks
April 18th, 2013 03:12 PM #2
its upon visual inspection or when youre having the car lifted to determine if its needed or not....well if thats the case sir have it undercoated before the rainy season begins ;)
April 18th, 2013 03:56 PM #3
April 18th, 2013 04:03 PM #4
some vehicle manufacturers stopped undercoating their products for two main reasons: to keep the car lighter, and, to prevent salt laden moisture from accumulating and getting trapped between the substrate metal and the undercoat.
what i have tested and proven on some of my cars, on the underside and the front around and below the radiator which is prone to splash from the vehicle ahead of you, is to apply vaseline or wheel bearing grease with a paintbrush to the susceptible areas. i tested this on a jeep wrangler, mazda 323, toyota previa, suzuki sx4 and other vehicles. apply the grease only in areas that are out of plain view and hardly if ever washed. the objective is to seal the metal from oxygen.
- Jan 2013
- 686
April 18th, 2013 04:08 PM #5
April 18th, 2013 06:24 PM #6
ilang patong ba ang advisable? me nagsabi kasi sakin na madaling mabakbak pag makapal ang undercoat. sa vios kasi 2 liters daw ang isang coat at 3 to 4 liters ang mauubos pag 2 layers ng undercoat.
April 18th, 2013 06:54 PM #7
May alam ba kayong gas station na nag ooffer ng undercoat kahit labor lang? May isang lata na kasi ako ng 3m rubberized dito, ang mahal kasi ng singil ng caltex retiro sakin, 2k labor lang...
April 18th, 2013 07:11 PM #8
is it true that mitsubishi cars don't need undercoat for the reason that it undergo 8 dips process?
what do you say?
- Nov 2011
- 473
April 18th, 2013 08:37 PM #9
April 19th, 2013 06:31 AM #10
The backup charger finally arrived. Here are my findings and conclusion at the end:
