View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 9,141 to 9,150 of 11542
- Jan 2014
- 158
November 12th, 2014 12:08 PM #9141thank you for correcting me sir hehe, . napa check kona yung tires eh sa minerva pa nga halos inalog alog nadin nila yung underchassis ko pero wala talaga so nung na test drive ng kaibigan kong mekaniko naramdaman niya din yung sound parang gumagasgas kasi at kahit apakan mo yung brake ramdam mo parang may gumagasgas talaga so sabi niya need refacing since im so noob sa car so i agreed kaya lang gulat ako sa price kaya gusto ko humanap ng 2nd choice since ang layo na ang mahal pa thanks sa advice Sir
November 13th, 2014 06:02 AM #9142
usually if your rotors need refacing, you'll feel the vibration on the brake pedal when braking. parang ABS yata yong feeling na always active heheh.
dr d is right, murang mura lang ang refacing. I can't recall sa exact price on my previous car, 2006 pa yon but for sure less than 1k lang binayaran ko for both front rotors.
- Jan 2014
- 158
November 13th, 2014 03:46 PM #9143
THanks sa info sir!
When i hit the brakes i feel tsug tsug sound yung parang gumagasgas tapos i feel it narin kahit hindi ako nag bbreak mas maririnig mo siya pag patag yung daan talagang parang may gumagasgas thanks for your inputs papa ayos kona siya tomorrow sa customers cradle
- Jan 2014
- 134
November 13th, 2014 08:14 PM #9144Mga sir 5w-40 ang ginagamit ko na engine oil per advice ng mekaniko sa shell dito samin. Tama ba yung grade na ginamit? Pansin ko kasi lumalakas vibration ng makina ng vios ko habang tumatagal.
- Oct 2013
- 2,537
November 16th, 2014 12:51 PM #9145yon lang, wala naman nakalagay sa users manual na pwede gumamit ng 5w-40! 15w-40 or 5w-30 pwede...
you exposed your engine to more wear by using the wrong oil... mas sundin ang advise ng users manual kase sila nag design ng engine at pwede sila kasuhan ng wrong info kaysa sa mekaniko... mapapagastos ka pa nyan tuloy
November 16th, 2014 03:16 PM #9146
or better yet, ask from your nearest casa. di naman kailangan dun mo ipapagawa.
been using full synth 5w-40 on our 06 vios ever since. wla na man prob, clocked 183,000 km last week.
- Aug 2012
- 53
November 19th, 2014 06:43 PM #9147Mga Ser,
Ano magandang lubricant ilagay para mawala un "squeeky clutch pedal" if nag chachange gear ka? Gragrasahan lng daw sa may clutch fork arm eh pero di ko sure what magandang pang lube...
- Aug 2012
- 53
November 19th, 2014 06:45 PM #9148Totoo ba na ang engine tune-up lng sa 2nd gen vios (2007-2009) including Yaris is change spark plugs and oil lng? since electric na daw ung mga VVT-i na engine?
- Aug 2012
- 53
November 19th, 2014 07:55 PM #9149Sorry kung npadami post... mgpapa PMS na kc ako ng 40k. I just got a quotation sa CASA... LANGYA! Php 6,166.91 for fuel filter plus 672 na labor... Halos 7k na.. Gnun ba talga kamahal un fuel filter? What makes it soo special? Baka puede ipagpaliban na to sa 80k PMS?
November 19th, 2014 09:34 PM #9150
Change plugs, filters and oil lang talaga ang tuneup. Wala na tayong distributor na kelangan i-timing. Pwede mo palinis ang throttle body.
Mahal talaga ang fuel filter natin. It's a big unit and it resides inside the tank. Cheaper if you get the part from Banawe but make sure it's original. May mga nagtry na ng replacement dito and hard starting na ang makina. Wag mo na pagpaliban yan. With the "quality" of our gas here malamang may bara na yan.Last edited by JohnM; November 19th, 2014 at 09:37 PM.
high idle RPM at engine start
