View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 450 of 580 FirstFirst ... 350400440446447448449450451452453454460500550 ... LastLast
Results 8,981 to 9,000 of 11582
    Jul 2014
    Jan 2014
    #8982
    Guys how often do we need to replace fuel filter? Kasi i just heard na matagal daw na process yon at hindi basta basta pinapalitan unless may prob. Saka mahal daw yun around 3k something daw yung filter palang. Pang 6th month maintenance kona kasi this is my 2nd hand car. Nung 3rd month kasi change oil and palit oil filter so now 6th month im planning to replace air filter and fuel filter . Need your advice guys thank you!
    Posted via Tsikot Mobile App
    Aug 2008
    #8983
    Quote Originally Posted by KrisVios04AT View Post
    According to the manual, every 80k kilometers dapat nagpapalit ng fuel filter. Bro mas mura ang fuel filter ng 1st gen compared to 2nd gen. 1.7k lang yung OEM na fuel filter for 1st gen sa Alabang Auto Parts, while 5.5k++ yung for 2nd gen.
    My advice: stick to OEM filters since yung mga 1st gen units sa fleet namin sa office nag-suffer sa hard starting nung replacement ang kinabit pero nung ibinalik yung OEM, naging okay na ulit.
    Jan 2014
    #8984
    Thanks bro crave! Andito kasi ako ngayon sa customers cradle nagpa change oil replace oil and air filters papa tune up kodin palit spark plugs and full body throttle at maf sensor cleaning. From january this year naman up to present nakaka 6,000 kms palang ako . Pero actual kms ko 170,600 na pero kaka pa change fuel filter ko lang lastjanuary
    #8985
    Maintenance Question:
    Last Oil Change - March 23, 2014 (DGU + Baldwin)
    Kailan ang susunod na palit? Kaya ba 1 year? hehehe! mahina padin ako sa mileage, mag 4 years pa lang yung auto sa sept-oct; 14T KMS pa lang
    And with that age, ano pa kaya ma-suggest niyo palitan ko? Fluids? etc....
    Sobrang busy sa trabaho diko na napapansin yung kotse eh..
    Jan 2014
    #8986
    Guys pwede ba mag spray ng perfume or lysol sa loob ng car? Para mas mabango? Hindi ba ma aapektuhan aircon or magkakabara sa aircon? Im using perfume kasi iniispray ko sa tsikot before i sleep or lysol din . Any inputs guys thanks!
    #8987
    may nagsasabi na yung perfume ay didikit sa aircon, and will attract dust. in the long run, it will cause diminished cooling and lower draft volume.
    ako? wa akong pakialam.. glade new car and glade lemon, here we come!
    Nov 2013
    #8988
    stick to products na meant for cars na lang. parang tumatapang kasi perfume pag tumatagal sa auto, sakit sa ilong.
    no freshners for me, i like the natural car scent.
    Jan 2014
    #8989
    Thanks for the advice ka tsikots!
    Aug 2012
    #8990
    hello mga sirs. pwede bang "mapalambot" yung clutch pedal ng vios natin?
    Jul 2004
    #8991
    Hi guys,
    Question lang regarding sa VIOS 2009 J (manual).
    1) May alam ba kayong temperature gauge na maganda para ilagay sa vios ko? Praning kasi akong mag overheat nalang yun na hindi ko man lang alam na umiinit na yung makina. Yung mga dati ko kasing kotse nag o overheat. (Nasira radiator fan / kulang sa water / leak / fanbelt/ etc)
    2) May alam ba kayong magandang backing sensor para hindi mahirap mag park. Yung tumutunog kung malapit na yung rear mo sa pader or sa ibang kotse? May pinakita na sa akin dati, may front viewer pa, pero hindi ko kasi alam kung magandang klase yun. Gusto ko yung maganda. Ok lang kahit gumastos ng konti basta yung reliable at matibay.
    Thanks.
    Dec 2013
    #8992
    Quote Originally Posted by joms View Post
    Hi guys,
    Thanks.
    Hello, about po sa back sensor, kung gusto mo sobrang accurate merong nagpost dito ng rear camera, back read ka lang ng mga 3-4 pages siguro.
    Tanong po mga boss, may alam kayong reliable na nagkakabit ng V-Kool na tint? ung mga base series lang para mejo mura. At pag nagpakabit ba, may bayad din ung pagpapatanggal ng existing na tint? TIA.
    Jul 2004
    #8993
    Jhanks - thanks pre pero ayoko actually ng camera. Pag sa bumper nakalagay yung camera, mahirap makita kung babanga ka na ba talaga kasi its not facing downwards. Kung sa may plaka naman sya naka kabit facing downwards, hindi naman sya magamit sa gabi kasi nasisilawan sya ng plate lights. Gusto ko sana yung tumutunog lang then biglang bibilis yung tunog pag malapit na malapit ka na sa wall/other car.
    #8994
    Share ko lang yung mga natutunan ko while using my Bluetooth OBD II reader. I've been figuring out the 'sweet spot' in the speedometer and so far this is what I have learned.
    80kph sa speedo, steady right foot, maintaining my speed ala-cruise control. Yung nasa lower left, average km/L which is not so accurate. Yung nasa mid-lower, instant FC, dyan ako nagbbase.
    Eto naman, foot off the accelerator pedal (Throttle Position 18.0% to 18.4% kapag di nakaapak). Around 70+ sa speedo. Take note na hindi same ang reading ng OBD II sa actual speedometer ng kotse.
    My findings, keep the rpm above 1600 for the DFCO to work. Kapag less than 1600rpm, I believe hindi completely shut off ang injectors. Also, don't spend too much time sa 2nd gear while accelerating. 4km/L ang reading sa instant FC kapag umaarangkada ng segunda. If possible, 30kph pa lang, shift to 3rd na.
    So far 390kms. na, 3 bars pa gas ko. I'm assuming more than 13.5km/L ang FC ko. Using Seaoil 91 all the way.
    #8995
    ^sir, yung OBD adopter, auto ON ba parati? or kailangan ON every time gamitin?
    Aug 2004
    #8996
    Reposting:
    Di naman nakakasilaw. Additional light pa nga ang plate lights.
    #8997
    good info para sa mga walang OBD reader :clap1:
    However, 1600 rpm for a fuel cut-off seems high. That's already twice the idling rpm. I was hoping a cutoff between 1k and 1.2k rpm.
    #8998
    Active sya palagi, kahit naka-off ang makina. Ioopen mo na lang yung app then turn on the ignition para mag-connect yung phone sa reader via Bluetooth.
    #8999
    Quote Originally Posted by blank check View Post
    Di ko kasi sure kung nag-ccutoff na rin everytime I let off the accelerator. Ang reading kasi, for example 50kph speed ko sa app, pag pinakawalan ko ang gas, naglalaro sa 50-60km/L yung reading. Halos equal sa speed mo. Then after a few seconds kapag ayun nga, everytime above 1600rpm ako, nagiging 70, 80+ minsan 90km/L ang reading. If not above 1500-1600 rpm, almost same sya sa speed mo. Maybe it uses up minimal fuel pa rin. If hindi 80+ km/L yung reading.
    Kapag maintaining 100kph sa car speedo naman, ang reading is 14-16km/L. Pinaka-matipid na speed IMO is 70-80. Our unit is 1.3 MT nga pala.
    Apr 2013
    #9000
    This idea/technique works for me. 13.14km/l
    20km/h = 2nd gear
    30km/h = 3rd gear
    40km/h = 4th gear
    50 or 60 km/h = 5th gear
    City , maintain 1700 - 2000 RPM
    Hiway, maintain 70 to 80kph
    dito ko rin to natutunan and it really works for me.
    Shell Fuelsave 400km/30.44 Liters
    konting practice pa... at iwas sa takbong 120 to 130.. mas makakatipid pa.
Toyota Vios Owners & Discussions Thread
