1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Haha. Mahal ah.
Wala pa. Busy eh. Tapos daming gastos. :D
Yung foglight switch ko pala nag-loose contact, so kapag dumaan sa uneven road kahit naka-ON, namamatay. Papagawa ko nalang dito samin, or ako nalang mismo titira -- di ako makapunta ng Banawe eh.Siguro nasira kasi hindi ko nilalagay sa "OFF" yung switch, parating naka-pindot lang.
Eh yung Tucson mo, kelan ba yan sasalpakan ng Sonata rims? :hihihi:
Mas mabuti kung ubusin mo muna
Sent from my LT26i using Tapatalk 2
Nag DIY kaninang umaga si sir John sa GB1 parking nung paano pagaganahin AUX sa HU. Good thing gumana raw sya sa gen 2 HU hehe. I was in the area kanina kaso di na ko nakasunod.
Btw sir John, wala raw sa mga nearby CDRKing sa GB nung Toyota 20pin connector. I have to contact their "stock room" pa raw, binigyan ako ng number to check which branches has the item.
so far the only things which were changed .
Front Brake pad , spark plug every 20K-km & air filter and Gear Oil . The air conditioning is great and until now the belts are still stocks
*Chickselog : Hindi nga po dito sa pinas yan , nag visit lang ako ke eprats ulit :sweat:. inabutan ko na 85k na siya ngayun ,
madaya walang tachometer ang vios nila![]()
Holding the high beam and low beam on simultaneously will shorten the lifespan of the bulb or can burn the socket due to the heat generated by the two operating elements inside one pressurized bulb (yung sa friend ko, pumutok dati).
Bumaho nanaman yung aircon kanina. Tangjuice naman oo, pano ba to mawawala
Itapon ko nalang kaya yung replacement air filter?
Sent from my GT-P7310 using Tapatalk 2
Grabe napag-initan na naman ako sa SLEX kaninang hapon. While I was cruising at 80km/h fast lane (puno kasi ng jeep yung slow lane), an albaster silver GM Honda City 1.3S from shoulder lane cuts me. nag-slow ako siyempre. after awhile, lumipat siya sa slow lane. nung mapansin niya sigurong mag-oovertake ako sa kanya (note : nasa fast lane pa rin ako), bigla siyang nag-signal na mag-memerge siya sa lane ko although wala naman dahilan para mag-merge dahil halos wala namang sasakyan. from that, humataw na ako. from Petron southbound until southwoods exit halos pinapantayan niya ako (nasa slow lane pa rin siya while nasa fast lane ako) at 160km/h. expected ko iiwan niya ako knowing na "pa-VTEC" na siya. nung umabot na ako 170km/h medyo naiiwanan ko na siya pero di masyado. nag-mabagal na lang ako nung papalapit na ako sa exit ko. habang nasa toll gate, may naamoy akong parang may gomang nasunog.
ano bang problema? maayos naman akong mag-maneho. bihira akong umabot ng 90km/h dahil nagtitipid ako at nasa slow lane lang ako palagi. nagkataon lang na congested yung slow lane kanina kaya sa fast lane ako napa-babad.
napansin ko lang puro GM yung mga "nakaka-sagupa" ko.![]()
Dapat may kasabay na rezing rezing music. Yung parang sa Initial D. Nanonood ako nito pati wangan midnight.
Kidding aside
May mga tao lang talaga na walang magawa kaya ganyan. Hindi ko na pinapansin yung mga ganyan. Dati pinapansin ko yung mga ganyan medyo sumsama pakiramdam ko. Tinigil ko nalang tapos nakikinig nalang ako sa Alternative/Rock/Pop/Pop-Rock music para gumanda naman mood ko
EDIT: Pogi din kasi vios mo bro crave. Maganda setup kaya ka siguro hinahamon lagi ng ganyan (mags + belta grille). Ang dating kasi sa akin hinahamon ka...
badly need help...my hid headlight still flicks even worst kahit naka off na ang engine...everytime after ko gamitin ang light..![]()
^Balik mo sa pinagawaan malamang palpak install or wirings or sira yung HID kit.
Sana magparamdam si sir JohnM dahil may tanong ako. :bwahaha:
*JohnM Sir after nung 20pin connector from CDRKing, ganito ba yung kailangan ko?
