leaking npo kasi ung seal nya lumalabas npo ung silicon sa loob kaya gusto ko narin palitan. any ideas how much po price ng bagong fan clutch?
Sent from my F5321 using Tsikot Forums mobile app
sir jasonrey, sent you pm sir
Sir, na-check ko yung ATF medyo clear pa naman, pero tinanong ko kung kelan huli. Hindi nila matandaan :c Is it safe to say na yung na po muna una kong palitan? Kaya po ba ito DIY? I have read, pati filter dapat na ring palitan? Ilang litro po ng ATF ang need ng Revo at anu maganda brand both ATF and Filter?
First time ko sa Automatic na makina, medyo nangangapa :c
Pero pag napalitan na po at ganun pa rin? Worst case is baba tranny na po ba? :c
Mga sir help naman,
Early this morning biglang ayaw magstart ng Revo SR (matic) ko, gamit ko kahapon smooth running until kanina.
Initial observation is nawala yung cranking at parang wala kuryente na pumapasok. Kapag iniistart nawawala yung mga warning lights (parang namamatay). Bago pa battery mag 1yr palang this november (Motolite gold 2smf). Voltage nung battery is more than 12V (analog lang yung gamit ko mga 12.4V siguro) di ko nacheck during cranking.
Ano kaya prob? Thanks.
Sana battery lang. pano ba majustify na dying na ang battery. Actually under warranty pa yung battery. Kung during cranking is bumaba ang voltage below (12V) will that qualify as dying and pwede pa warranty.
Hi, can anyone share what oil they use for a 99 revo glx a/t gas? Thanks!
Sent from my EVA-L19 using Tsikot Forums mobile app
Got it. Thank you!And what about for atf dialysis?
use original toyota type t-iv atf
any 15w40 mineral oil will work. shell mechanics probably know the total liters...
Does anyone know how much is a clutch fan/fan clutch (?) for the revo? Had our aircon fixed, put freon, also put silicone oil, but now it's not cold again. Mechanic noticed before that previous mechanic put a some type of cloth ot rag inside. Just wondering how much damage this item would cost. Thank you
i had mine replaced with a replacement clutch fan, its around 2k of price, works great, disengages when engine is cold and engages when hot helping the engine run more efficiently
dr. d is right, you have other problem in your a/c system. in your story a rag was put inside the clutch fan, the intention of that mechanic was to make sure your fan is always engaged at the expense of efficiency, it means your fan spins the same with your engine rpm no matter what. Your A/C system should be pressure tested to find leaks...
Had it fixed na. Culprit was the auxiliary fan and condenser (plus bracket). :/ No need to change clutch fan. Damage, with additional freon since it disappeared again, is 3500.
