Page 2 of 35 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 1447
    Nov 2011
    Quote Originally Posted by zap.FREEDOM View Post
    good day sir, about your question, yes normal lang po sa steering ng Revo yung lambot, napaka-easy talaga to manuever ang steering niya, even your just using three fingers it can, regarding sa pagiging sloppy, well, baka naninibago lang po kayo since subcompact car ang dala niyo noon at AUV naman ngayon, may be you can check the steering pump belt na rin po kaya parang delay ang response ng steering.
    have a nice day
    Good morning din sir. Thanks you for the reply. I'll check yung belt muna. Pag ka nagpapark nga ako sa bahay e parang me lumalangitngit na konti pag nag-issteer ako ng manibela. Ano ba yung indicator ng worn steering pump belt bukod sa mga visible cracks at gaano katagal ang effectiveness ng belt nya. Thanks uli sir. Looking forward for more responses.
    Jan 2011
    Quote Originally Posted by nolicorpuz View Post
    Tama yung comments at suggestion ni bro zap, kung visible na yung mga cracks sa belt, better na palitan mo na kase dumudulas na yan kaya lumalangitngit pag nag steer ka, tip ko lang din sir para tumagal yung steering parts, better wag mo ibabad ng sagad yung steering wheel pag nag left or right turn ka, yan din nagiging cause ng hindi tumatagal yung steering pump at steering gear, and also better moving or iusad mo yung car mo bago ka mag steer.....good choice sir sa nakuha mong AUV
    Aug 2010
    hmm,..siguro nga steering pump belt na yan on, maluwag na po yan, madali lang yan, pa-adjust/tighten mo lang yan sir sa mga service station sa gasolinahan or to your friendly mechanic pwede rin DIY kaso baka mahirapan kayong magpihit ng screw para mag-tension/tight, yung samin kasi, in 10 years of age na, pero twice pa lang pinapalitan ng steering pump belt, bale adjust-adjust lang, tight-tight lang ng tension, check niyo na rin po yung wheel alignment, tire wear, tire pressure kaya sigruo nagiging sloppy.
    May 2011
    good day mga sir,
    ask ko lng po kung ano tumutunog s bandang harap na parang squick sound/ or parang mahinang pito. tuwing dadaan ako sa humps?at saan magandang magpagawa? badang mayon qc. po ako
    revo 2002 vx200 gas poyun sa amin
    thanks a lot sa reply
    Nov 2011
    Quote Originally Posted by sgtoda View Post
    good day mga sir,
    Baka ball joint na yan.
    Is there anyone here tried NANO ENERGIZER? :popcorn:
    https://www.facebook.com/nanoenergizerofficial
    Jan 2013
    hello po, sino po kayang may alam kung saan pwedeng ipagawa ung automatic antenna ng revo gsx ko, hindi po cya gumagana pero may maingay po pag start at stop ko ang makina, parang ung motor o gear nung antenna, salamat po.
    Aug 2017
    Good day mga sir. I have a Toyota Revo 2004 1.8 GLX silver po. Owner driven and really don't have any problem with it. Aesthetically maganda pa po, napa repaint (wash over yata sabi nila) two years ago. For 14 years with me, ito palang po napagawa ko: tires changes, belts, batteries changed three times, clutch fixed twice, shock absorber changed once, tapos puro regular PMS lang. I am planning to sell it na to change to a smaller car coz I do not need a big space now and would save on the fuel consumption as well.
    Tanong ko lang around magkano price range can I still sell it for? Para may ball park figure lang ako when I go to mga second hand car buyers or kung may kakilalang gustong bumili, and I would know kung nasa tamang price range po. Kasi I was looking at mga online second hand sites parang anlaki ng price range from 150k to 380k. Salamat po ng marami...
    Quote Originally Posted by cirdeolavar View Post
    there is no hard and fast rule, po. but perusing the for sale sites, as you did, is a good idea. be aware, however, that cars can be made to look very nice, in the pictures. only upon actually visiting and seeing the car up close, does "nothing to fix" translate to "not worth fixing". so how does you car measure up?
    start with the higher asking price, and go down if you are desperate at selling it. there is a saying, "at the right price, anything will sell". how desperate are you at selling?
    and good luck with them bayan sellers. heh heh.
    i used to have a revo (diesel). only after selling her, did i miss her. the sedans and innova do not drive like her.
    Aug 2017
    Thanks for the reply po. Yeah i will surely miss my Augie... (name ng revo ko) medyo may sentimental value I know revo is not much but a practical car but kasi sariling ipon ko po kasi to. But then, I think I would save on the long run and be more practical if I switch to a small car.
    The body, mostly sa bumper has a few scratches, interiors naman back aircon a few panels that I glued which becomes fixed, coffee stains on the cup holders, engine naman hindi cya maingay, still very presentable naman cya. hehe.
    Cge po, I'll start asking higher and go down pag mag haggle na. marketing strategy parin. lol!
    Sep 2017
    I'm planning to buy a 2nd hand na revo or adventure or crosswind. Ano po ba maganda jan sa tatlo?
    Jan 2003
    thanks
    Jan 2003
    to all,
    i just had my 2nd to the bottom leaf spring removed, big difference. i change my front shock to the ac delco once. not bad. the ride is better than original. now , the ride of my glx revo can be compared to the innova or better. my suspension setup is ac delco shock (front), rancho rs9000 (rear) with the removal of one leaf spring.
    May 2007
    Quote Originally Posted by rsvtec View Post
    to all,
    Hello Rsvtec,
    Hindi po ba tumutukod kapag puno? same setup pa din po ba until now?
    Thanks!
    san po ba ako makakahanap ng 98/99 model headlights for my revo..katulad ng nasa pic ko or better looking headlight casing?..nakita ko kasi sa other website itong pic ko...
    and san po makakabili ng mura na headlight casing?
    rsvtec,
    pa-post naman ng pics dito or sa yahoogroups, the shops and cost involved in your suspension change ...until now kasi eh stock pa din suspension/leaf spring ko hehe
    thanks
    Jan 2003
    medyo madilim lang but viewable.
    black glx 1.8 at
    -prado spoiler with brake light
    -hood guard
    -rs 9000 9 setting adjustable rear with remove 1 piece of my leaf spring
    -ac delco shocks for the front
    - modified accord chin for the front bumper
    - plasma tv with pioneer dvd player
    -roof rail , side step board , rain guard
    the place I had the shocks installed is at automotive one on del monte corner d tuazon. for the ac delco shocks joshua gave it to me for 800 each. and labor for the removal of the leaf was 400 each. he has ac delcos for the rear too. 200 pesos for the installation
    Sep 2005
    Sir, pwede malaman full details nag store name, streets and contact no. for delco shocks. Salamat po
    black glx 1.8 at
    -hood guard
    Sep 2005
    Sir, pwede malaman full details nang store name, streets and contact no. for delco shocks. Salamat po
    Hello guys,
    Gusto ko rin sana mag join sa club nyo, nag fiil up na ako sa web site nyo, may Revo din ako dyan sa pinas, gusto ko rin e-set up. may tanong sana ako kung ano ang size ng rim? kasi gusto ko bumili dito sa US. hoping to hear from you soon. Thanks and gud luck.
Toyota Revo Owner's Club Details
