Results 651 to 660 of 1441
- Apr 2008
- 6,237
August 20th, 2014 02:13 AM #651Kaibigan ang may-ari ng A1, and he inspected my car personally. Di naman siguro peke ang silicon oil. Denso ang tatak.
Nung una kasi ubos na ang silicon oil. Hindi bumibilis ang fan habang tumataas ang rpm. Pareho lang lagi ang fan speed sa speed nya tuwing idling rpm. Ngayon bumibilis na siya proportionate to engine rpm.
Sent from my GT-I9100 using Tapatalk 2
- Jul 2011
- 71
August 21st, 2014 09:51 AM #652
- Jul 2011
- 71
August 21st, 2014 09:56 AM #653
- 52,731
August 21st, 2014 10:08 AM #654heh heh.
couterfeits are really difficult to detect. the more reliable way is to ask, and the seller tells you.. "boss, eto, genuine. 100 kesos. eto naman, mas mura.. 50 kesos lang. but ok experience namin dito." buyer bahala make decision. but not every seller is this honest.
as to your brake light problem, i once had to replace my brake light switch. mine, as i believe in other cars', was under the dash, amidst the pedals. the brakelight switch actuator lightly touches the brake pedal lever. you'll have to squeeze yourself in there to see it, and curse your parents why you were not born with four joints in your arms and eyes like other animals' ...
the handbrake warning light switch is beside the handbrake naman daw.
good luck.
- Aug 2012
- 2,767
August 21st, 2014 10:34 AM #655
- Apr 2008
- 6,237
August 21st, 2014 10:39 AM #656Nice to hear from you again! Saludo talaga ako sa Revo mo tol! Yung samin 111tkms palang ngayon falling apart na! Sana talaga maayos na ng husto. Hindi ko kayang dalhin to out of town in this condition. Considering all the stuff I've already replaced, do you think there is anything else that needs replacing?
August 22nd, 2014 12:57 AM #657
Yes sir sulit talaga yung revo namin sa laki ng mileage, first time niyo ba palit ng Tbelt? Yan talaga ang quote sa casa but for my experience sir since before Tbelt lang pinapalitan ko, check mo ng maigi yung idle bearing hindi naman basta nasisira yan, babad ko lang sa oil mga ilang minutes hanggang makapenetrate sa loob oil pero hindi ko siya binunuksan dahil sealed bearing yan pero depende kung hindi na ok pag inikot mo na may possible na magstock up pero its up to you sir at yung sa oil seal hindi naman basta magleak yan comapre sa 4D56 engine. kaya yung gastos ko labor (800 petot) at Tbelt lang (casa)
August 22nd, 2014 01:18 AM #658
Sulit naman talaga bro yung revo talaga based sa experience namin, pero hindi naman basta mag fail yang revo mo bro kung yan lang yung problema, basta alerto lang lagi sa temp gauge, yung fan blade napalitan ko na din pala mas malaki siya compare sa orig kaya maganda ang hangin.
Sa amin nga dami na din pagawain eh kumapara diyan sayo, pero daily drive pa din ni erpat lalo na yung differential palitin na at propeller tumatakbo pa din, ngayon na overhaul, '01 model un, another 13 years or more kase ngayon private use na lang
- Apr 2008
- 6,237
August 22nd, 2014 01:24 AM #659Ah. Anong fan blade gamit mo? Kelangan ba modification? Mas maganda kaya kung gawin 2 ang aux fan?
Ngayong umaga nahalata ko lang na umaangat ang temp ng konti (konti lang naman) from normal habang tumatakbo ako sa Quezon Ave. and then along G. Araneta. Basta't lumagpas ako ng mga 90km/h aangat na siya. Hindi pa natry sa highway to see kung tutuluyang umangat nga ba. Any suggestions as to what may be amiss?
August 22nd, 2014 04:49 AM #660
Hindi naman ako nag modified ng blade, nasakto lang kase nung nasira yung fan blade dahil last time pagkatapos magpa cleaning ng radiator pinaandar ko engine tapos hindi pa pala naka turnilyo yung mga nut ng fan, ayun alam mo nakuha ko din sa banawe nung naikumpara ko sa orig, mas malaki yung blade mismo kaya mas ok yung hangin.
Nagpalit ka na ng thermostat? baka hindi na ok yun pag tumatakbo tapos sa ganung bilis dapat hindi tumataas ang temp. try mo muna tanggalin para matesting tapos pag naging ok naman yun ang cause sa thermostat then palitan mo na lng bago.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
