Results 421 to 430 of 1441
August 24th, 2012 06:04 PM #421
your welcome bro, mahal kasi kung ipapasok mo pa sa casa ng toyota para lang ipa-check at ipapacondtion ulit lalo na dyan sa alabang, tatagain ka lang sa presyo, madali lang naman ipa-condition at gawain kung magkakaroon ng sira, even a backyard mechanic is knowledgable in that.
bro, Aisin G52 yung nasa Revo. maganda yan G52 na yan, matibay talaga, since low speed yung mga gears, easy-easy lang pag-umaahon (parang nagmumumog lang, hahaha!), you don't need to step hard on gas pedal when climbing uphills, yun nga lang dahil low speed, medyo makupad pagdating sa patag...about sa A/T, no idea e,
- Mar 2009
- 81
August 29th, 2012 11:33 PM #422guys pa help naman. nag pa gas up ako kanina engine off then nung magstart nako hindi siya mag crank. may ilaw siya sa panel at humihina lang sila kapag pinihit ko na yung susi, napansin ko parang kulang sa kuryente. yung battery nya motolite maintenance free at halos mag 1 1/2yr palang. anu kaya mga possible problema? nagstart lang siya after ng 4 attempt ko istart. diesel 2004 glx ride ko nga pala. okay naman mga terminals nya. all stock.
- Apr 2008
- 6,237
August 29th, 2012 11:50 PM #423
- Mar 2009
- 81
August 30th, 2012 12:08 AM #424
- Nov 2011
- 31
August 31st, 2012 05:42 PM #425
August 31st, 2012 10:30 PM #426
1 1/2 year will be equivalent to 18 mos. yung motolite enduro has 15 mos. warranty, yung gold 21mos. ata if im not mistaken and yung excel is 24mos. warranty, ano motolite variant ba gamit mo? possibly yung enduro may mga rare cases na bumibigay agad after the warranty has gone. if it is not battery the problem cause possibly by failed alternator, failed starter (may be, worn out carbon) or faulty voltage regulator.
- Nov 2012
- 47
December 1st, 2012 04:07 PM #427Hi guys. Question lang po. Talaga bang Premium Gas lang ang pwede sa Revo? Di po ba pwede ang Regular Unleaded Gasoline? By the way I have Revo 2003 GL. Thanks
December 1st, 2012 11:22 PM #428
- Apr 2008
- 6,237
December 1st, 2012 11:39 PM #429
- Nov 2012
- 47
December 5th, 2012 04:24 AM #430sorry po sa nonsense question ko.
mga sir another question po.
What kind of bulbs are used for the following:
parklight
turn lamps
brake lights
reverse lights
bulbs sa gauges and
bulbs sa dashboard
Thanks a lot in advance. and sorry po if nonsense question ulet. Noob lang. ...
high idle RPM at engine start
