Results 9,231 to 9,240 of 15330
August 30th, 2014 12:39 PM #9231
Last time I ask the dealer if how much it will cost me to replace my panel gauge sabi nasa 20k daw.
Posted via Tsikot Mobile App
August 30th, 2014 01:10 PM #9232
- Oct 2013
- 1,181
August 30th, 2014 02:13 PM #9233Diesel? Alin na fuel logo, dalawa yan, isa sa empty at isa sa change filter. Kung yung change filter, reset your ECU.
August 30th, 2014 03:08 PM #9234
Vvti second hand,pinakielaman ko lang Kaya nag ka ganon,I found out that innovas panel gauge uses led or parang IC light unlike ng adventure namin na may mga bulb.
- Oct 2013
- 1,181
August 30th, 2014 05:36 PM #9235Mukhang yung optitron ang gauge mo. Yung sa amin hindi optitron kaya buldang gamit.
Ano ginawa mo sa panel? I have been resetting innova odometer, pero di pa nangayri yan experience mo.
Reset mo ecu or check your fuel float, baka yan issue.
Ako yung experience ko sa akin kapag nasa below half na ang gauge, and naka idle ako ng mga 10 minutes, bumababa yung gauge, pero pag andar balik normal.
- 52,731
August 30th, 2014 05:56 PM #9236
August 30th, 2014 08:02 PM #9237
Sino na dito nagpalit na ng timing belt?
Kasi 10k nalang saakin palitin na
Does anyone know where is the most reliable place to buy
or sa casa nalang?
- 52,731
August 30th, 2014 10:04 PM #9238
August 30th, 2014 10:25 PM #9239
Pardon me sir Pero wala po,I just want to see and know how this and that looks like and where and what thing you can see inside of the panel gauge,I remove the needle hand po kase,isang buong assembly po yan and it is divided into three or four panel tas yun Para ma access ko yung mga ilaw I remove those needle and when I put it back again Hindi ko na balik sa dati ang style dapat. Ung needle ituro mo na sa zero sa rpm and speed same as the fuel and temp..Pero Hindi ko na binalik sa dati ang hirap tanggalin ng mga kamay nya matigas -_- ....I dunno if optitron po to pero may adjustment to sagilid ng steering malapit sa tuhod mo.
- Oct 2013
- 1,181
August 30th, 2014 11:26 PM #9240The easiest way to remove needles sa gauge ay gamitan mo ng tinidor as lever. Alam ko itsura ng instrument cluster nyan as I have been resetting odometers as a hobby. Just make sure lagyan mo ng cloth sa papatungan ng tinidor mo sa cluster para hindi magkamarka.
Servo type motor ng needle nyan, di kagaya nung old school na parang basta may coil lang.
Check your RPM, Speedometer and temp if calibrated pa sa sasakyan mo, wala needle stopper ang innova, so sa pagbalik ng needles, make sure counter clockwise ang paglagay mo kasi yung stopper nyan mismo ay sa motor.
Bigat paa :grin:
(2023) Ford Territory
