Page 775 of 775 FirstFirst ... 675725765771772773774775
Results 15,481 to 15,487 of 15487
    Apr 2005
    #15481
    Daylight sensor.
    Sa 1st gen Innova, alam ko isa lang function.... Lumalakas yung A/C fan speed (kung naka Auto yung A/C) kapag mainit sikat ng araw.
    Sa 2nd gen Innova, aware ako sa dalawang function.... Kapag naka-On or Auto yung parklight o headlight, lalakas yung instrument panel at headunit backlights kapag tirik yung araw. Yung 2nd function ay similar sa 1st gen Innova... ie. lalakas yung A/C blower (Auto A/C) kapag maaraw.
    Napansin ko nga na habang naka Auto ang aircon biglang lumakas ang blower.
    Anong generation po ba ang 2011 model?
    Jan 2009
    #15482
    Quote Originally Posted by SEALANDER View Post
    1st gen... hanggang 2015-2016.
    2nd gen... 2016 hanggang ngayon.
    3rd gen (Innova Zenix)... 2023 hanggang ngayon
    Apr 2025
    #15483
    May experience ba kayo na di nag shift to 4th gear AT gear box?
    1st gen VVTI and highway is 9 km/l lang. Napansin ko na hanggang 3rd gear lang going from 0 - 100. Going from D4 to D3 no downshifts din even at highway speeds.
    I'll see if makuha sa ATF and filter change. May mga nabasa lang ako from forums abroad for other toyota models na pwedeng cause is faulty ATF temp sensor. Pag di mainit yung ATF e di magshi-shift to 4th gear. Anyone here knows kung anong part number ng ATF temp sensor and kung saan makakabili?
    Thanks
    Jan 2009
    #15484
    Quote Originally Posted by delenter View Post
    Thanks
    Though it is possible that the problem is as simple as you say, a temp sensor, but it's better to have it properly diagnosed first. Validate ATF temp using a diag tool that can read live data. Requires Techstream for that generation Innova because it's not OBD2 compliant.
    #15485
    Daylight sensor.
    Uy, bago sa aking kaalaman iyan ha?
    Will check tonight....
    Jan 2013
    #15486
    Nagkaroon ng tagas ng langis yung timing chain/belt cover ng Innova 2013 G Gas ko.. just wanted ask from the group kung magkano magagastos ng pagpa reseal ng timing chain/belt cover? TIA.
    Jun 2011
    #15487
    Malamang valve cover gasket set ito, kasama ang 4 na parang bushing para sa abang sa spark plugs. Baka mga 2k ang set?
    Quote Originally Posted by homhomnova View Post
Toyota Innova Owners & Discussions [continued 3]
