Results 2,771 to 2,780 of 15330
- Mar 2012
- 2
March 17th, 2012 09:04 PM #2771Hi, i'm new here & just got our innova last 2 weeks. I'm just curious about the tire pressure, our SA said that I put 29psi for the front & 30psi for the rear tires but the manual says that tire pressure should be 33psi for both front & rear(unloaded). What could you recommend based on your experience?
March 17th, 2012 10:28 PM #2772
March 17th, 2012 10:47 PM #2773
Sa mga nakaka-experience ng fumes getting in to your rear aircon, check you rear shutter flaps passenger side doon dumadaan ang usok galing labas.
Had my aircon cleaned and rear evaporator replaced today, found out also today that the rear aircon is not recirculate it gets outside air from the shutter flaps. The rear aircon assembly has a tube connected directly on the passenger side shutter flaps.
Problem with the shutter flaps is that it has no user control on opening or shutting it close, control is only by cabin pressure.
March 18th, 2012 01:35 AM #2774
- Apr 2005
- 130
March 18th, 2012 11:07 AM #2776
the rubber flaps are located at sides of the rear bumper. the flaps are one-way and if air is sucked from that portion, the flaps actually will close. the fan does not suck air from the outside but from inside the cabin. i intentionally covered the opening of the rear fan before and no air comes out of the rear air-con vents.
March 18th, 2012 12:47 PM #2777
- Mar 2012
- 2
March 18th, 2012 12:51 PM #2778
March 18th, 2012 01:31 PM #2780
1st Gen LOOK: Mitsubishi Xforce B-SUV already in PH | Autoindustriya
Mitsubishi Xforce
