Results 2,651 to 2,660 of 15330
March 7th, 2012 09:31 AM #2651
you have to remove the bumper to see the flapper. medyo tricky yung pagtanggal ng bumper. yung mga bolts madali lang but then yung mga clips underneath the bumper may special tools sila. nakasira ako ng isang clip. humingi na lang ako sa tpt. eventually marunong na akong magtanggal using just 2 small screw driver. pasensya na mahirap iexplain. sa mga latero magaling sila dyan
March 7th, 2012 10:52 AM #2652
yes i know those holes. they are basically in -line with the holes above ( the one for the clips.) so if the holes on top are covered by clips then there should be no open holes going to the cabin. i want to help also and would like to understand why on some units , may pumapasok na amoy and some wala. i tried to spay some air-freshener ( Dakota Odor Bomb to be exact ) on those holes below ( near spare tire ) to check and luckily i did not smell anything inside the 3rd row even with rear blower at low/high setting. not sure for lower variants if the wire above is present and no covers for the wire clips. this might be source.
can you check your unit if the holes above are all covered?
March 7th, 2012 11:21 AM #2653
hindi ko po ma check. wla po ako sa pinas right now
i remembered something, when i removed the rear right siding on the 3rd row seats, comming from the blower dinukot ko po kung may connection yung rear chasis sa blower (parang elbow), as far as i remember parang tuloy tuloy. naisip ko ata noon na dapat may nakaharang doon sa may elbow. one thiing to check din is the rear right signal light. pag hindi maganda ang lapat may chance din na pumasok dito.Last edited by wakin; March 7th, 2012 at 11:32 AM.
- Aug 2011
- 338
March 7th, 2012 12:22 PM #2654
March 7th, 2012 02:07 PM #2655
March 7th, 2012 02:52 PM #2656
hindi ko pa naman na experience yun may pumapasok na amoy galing sa labas yun innova ko..siguro dahil naka wrap ng bodykits sakin..
March 8th, 2012 03:16 PM #2657
Without removing the rear bumper or peeking underneath the vehicle, this is the only hole I saw at the rear when you open the rear door. Wala naman akong naamoy na galing sa labas through the aircon vents. Innova-G, M/T, gas, January 2012. I don't know what this hole is for. Magkakaiba ba tayo ng design sa part na ito?
March 8th, 2012 03:47 PM #2658
that's for lowering the spare tire. it seems you do not know how to remove the spare tire. that's the 1st thing i did when i got my unit. save yourself the trouble incase you encounter a flat tire. one of my friend took hours to figure out how to remove his tires.
March 8th, 2012 04:16 PM #2659
If you learn how to lower the spare tire of the Innova, you will have no problem dealing with the Fortuner, Hilux and other Toyota products (e.g. Land Cruiser and Prado) which use a similar arrangement.
The worst possible time to learn it is by the side of the road in the middle of rainstorm.
There is some assembly required to build the hand crank you will need to lower the spare.
And the Innova jacking points are under the car, so you will use the hand crank to position the jack also. Otherwise you will crawl on all fours to reach the jacking point.
The lug wrench is part of the hand crank system.
It won't take more than ten mins to lower the spare and change the flat if you know how. It's kinda fun to do too. hehe.
March 8th, 2012 04:17 PM #2660
anyone here install the CARPRO UVX ceramic tint ? feedback please about the product specially...
CARPRO UVX Window Tint - Any Feedback
