Results 2,511 to 2,520 of 15330
February 21st, 2012 05:40 PM #2511
Up!
I would really like to hear from G and V owners if you ever experience smoke from outside entering the cabin through the a/c system. I never had this problem with my Fortuner which had denso a/c system.
We are deciding whether to get a 2012 Innova G and want to make sure this does occur with the G variant.
Thanks!
February 21st, 2012 06:36 PM #2512
February 22nd, 2012 01:24 AM #2513
ah i see bro. pero anu gamit mo pang linis dati sa upuan? mas mahirap ba linisin yung seats ng V? ako kasi nahihirapan maglinis sa sidings natin, G naman yung sakin. same pinanglilinis mo sa sidings at upuan bro?
sakin di pa natutuloy yung balak kong leatherette seat covers, probably this vacation ko, me pasok pa kasi ako sa school, di masyado maasikaso. tsk. BTW, anu yang sa seat covers mo bro, japan leather or german? may nakapagsabi kasi sa akin na japan leather daw mas matibay? yun kasi ang ipalalagay ko.
ayun sir Nognovot nga pala, naalala ko na! :D
V din sa inyo bro? mga V talaga mga bigtime. sarap maki-sakay sa inyo sa 2nd row!
panu sir nangyayare? bat di mo ipa warranty? sakin sir 2011 G owner ako, na experience ko yan minsan at napansin ko amoy usok sa loob, pag tingin ko sa AC ko, di pala naka circulate mode, nakalagay sa screen is yung arrow from the outside going inside kaya ayun naamoy ko usok sa labas so i pressed the circulate mode and it did not happened again to may innova. napindot lang siguro ng ermats ko yung isang button kaya pumasok sa loob amoy usok pero di na talaga na ulit.
- Jan 2010
- 304
February 22nd, 2012 08:49 AM #2514
February 22nd, 2012 09:48 AM #2515
Actually the air intake opening has rubberize foam lid on the edges, in due time this rubberize foam gets brittle and cracked. You can replace them with silicon rubber or rubber from tire interior cut-out AND/OR permanently sealing the opening with a glued thick plastic sheet.
February 22nd, 2012 10:01 AM #2516
February 22nd, 2012 12:49 PM #2517
February 22nd, 2012 02:42 PM #2518
February 22nd, 2012 11:01 PM #2520
try out some All Purpose Cleaners like Megs APC+ or Optimum Power Clean to clean seats and other surfaces. If it can clean this accumulated dirt then it should be easy to clean minor stains.
Ang nakikitang kong positive ng PPF is if the time comes to sell your car, you can remove the PPF....
Ceramic Coating vs PPF (Paint Protection Film)
