Page 3 of 28 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 559
    Aug 2009
    #41
    thank you for the quick respond sir miles. I usually fill my tank weekly or if the gauge is within the half of fuel indicator. I never had it below half. mostly it cost me 1,000 per filling.
    Apr 2010
    #42
    hmmm...i just filled up my innova vvti 2010 coz im planning to measure its fuel consumption after the 1k pms, hoping to see better fuel economy, but now im worried
    Jun 2010
    #43
    *miles2
    Same problem here. Mine was replaced recently. Do you know where we can sell this defective fuel tank?
    Aug 2006
    #44
    Quote Originally Posted by tggerhapi View Post
    *miles2
    Actually the gas tank can be repaired using hot rod and lead. I have seen at the dealers service bay that they also repair gas tank via outside contractor, the contractor pulls out the defective tank and then returned after the repair. I ask the contractor and he told me he is from Paranaque and they would do a water immersion technique and hot rod with lead, "suplete" at "tingga".
    Have you also replaced the "Charcoal Canister" and the "Filler Cap"? If not there is a huge possibility that your new gas tank will get warped and leak again just like what happened to me during my 1st gas tank replacement.
    Jan 2010
    #45
    will you agree to "repair" the problematic gas tank? lalo na if under warranty pa? di ba dapat replacement at hindi repair lang...
    i wonder if vacuum ang problem ... sa tingin ko kasi baka manipis yung material ng gas tank... dapat makapal na sheet schedule ng lata....
    in the long run yung repaired gas tank sa ibang part naman mag warp yun... masisira din...
    di kaya mine menos tayo ng TMC?
    di pwede pukpok
    Jun 2010
    #46
    Quote Originally Posted by Mile2 View Post
    *Mile2
    Yup the "Charcoal Canister" was replaced and but still waiting for a new stock of "Filler Cap". Sad to say we have the same case, on my 1st fuel tank replacement, they didnt replace the charcoal canister and filler cap.
    I'm looking for a buyer of these fuel tank. i have 2 pcs
    Aug 2006
    #47
    *tggerhapi
    Try calling Gant Auto Shop (2742-D Taft Ave., Pasay, T:831-6932) for the Filler Cap. Dito rin minsan bumibili ang mga casa pag sinabi nila sa iyo na by order ang hinahanap mo, panigurado meron sa Gant at mas mura. Kahit malilit na mga plastic clips meron sila.
    Kabibili ko lang ng clutch cover, disc at bearing na all Toyota Original sa Gant last Saturday at ang laki ng savings ko compared to casa price. Sa Casa by order ang clutch set at ang mahal pa.
    Jun 2010
    #48
    *tggerhapi
    *Mile2
    Dito din ba sa thread yun nagpagawa ng fuel tank cage to protect the tank?
    #49
    *tggerhapi
    Mile2, how much ang total cost ng clutch cover, disc at bearing for the innova? Had my transmission pulled down by casa ( warranty claim ) last month to fix a squeaking sound whenever I depress the clutch. pero sabi ng warranty section wala dawpinalitan na parts. although nawala naman yung sound, I'm not sure kung kelan ito babalik.
    Aug 2006
    #50
    P7K flat sa Gant. (cover, disc, bearing), sa casa almost P10K at by order pa, mukhang bibili pa sa Gant .
    Jun 2006
    #51
    pati pressure plate pinaltan mo din?
    Jun 2010
    #52
    *Mile2
    Contributing factor din ba kapag laging full tank?
    Aug 2006
    #53
    *Mile2
    Not sure about this. But casa supervisor told me it is best to keep always at half tank level.
    Aug 2009
    #54
    sir mile, can you elaborate more on half tank level. In my part I put gas once a week when my tank is at half level, atleast 1,000 per gas that will make almost at fulltank.
    Aug 2006
    #55
    Quote Originally Posted by annika View Post
    What the casa supervisor told me was, if you reached below half tank then that's the time to refill.
    Aug 2009
    #56
    thanks a lot, mile2.
    Jun 2010
    #57
    Nakakalungkot naman, I have been following all the threads kasi my family is planning to buy innova (J-variant). Pinagpipilian namin kung diesel or gas, but since me problem nga sa D4D parang gusto na namin ung gas. Pero eto na naman meron pa palang problema din. Sa family, we own only toyotas... pero parang we will consider other brands na. Tsk...kakalungkot
    Jun 2010
    #58
    *onguy14344
    Atleast, you know what to expect, and inspect when you buy innova. but honestly I'm satisfied with the perfomance of this car, 5 yrs na etong sa akin pero ganda pa rin ng hatak ng makina. Sana nga lang magawan ng permanent solution yun problem sa fuel tank.
    Jun 2010
    #59
    *onguy14344
    *tggerhapi, sir nagpalit na kayo ng Gas Tank, Charcoal Canister at Filler Cap? Di ba nasolusyunan ung problema?
    Jun 2010
    #60
    Mga sir,
    Magkano po kaya ang aabutin sa repair ng Gas Tank at change ng charcoal canister at Filler cap if ever ako po ang gagastos? San po kaya pwede pagawa if not in casa. Pasensya na po pero naghahanap lang po ako ng mga factors para Toyota innova pa rin po ang kunin ko... gusto ko talaga innova lalo na sa interior nya. pakidelete na lang po kung OT.
Toyota Innova Gas Tank woes
