Results 31 to 35 of 35
- Mar 2009
- 2
December 18th, 2013 04:06 PM #31I also have a 05 D4D innova. They told me to have the SCV changed. Also to have the injector cleaned, I think I'll try this first. How is it so far? Thanks
December 18th, 2013 04:11 PM #32
Are you encountering power loss sir? What is your odo meter reading now sir?
Sent from my iPad using Tsikot Car Forums
- Aug 2010
- 24
February 28th, 2017 07:29 PM #33I finally solved the gradual engine power loss on Innova D4D diesel by having the fuel TANK pulled down and cleaned. Diesel fuel is quite dirty and over time it accumulates in the different parts of the car. It is required to regularly replace the fuel filter in the engine. But there is a filter INSIDE the tank of the Innova. Another recent experience is when the pipes to the injectors were removed while replacing the valve cover gasket due to oil leak. The engine regained power possibly because some accumulated dirt was removed from the pipe line to the injectors. Cleaning the injectors might have minimal effect but this may have been cleaned in the process of removing the injectors.
Another issue is when I experienced sudden power loss after the SCV was replaced, again while trying to improve or recover power. The car went into "Limp Mode" or would stall or run only up to about 15-30kph. The cable to the fuel pump temperature sensor was loosened or disconnected. Reconnecting this properly, observing correct polarity, solved this problem. More info on this with pictures can be found in facebook page Toyota Innova Owners Phils.
- Oct 2017
- 1
October 26th, 2017 06:02 PM #34
October 26th, 2017 06:44 PM #35
Diesel fuel, in itself, is quite clean. The 'dirt' that is seen accumulating in the tank and sometimes clogging the filters are likely caused by Diesel Bugs. They thrive where there are water molecules or condensation and when there are air pockets. The fuel is already treated with biocides when they leave the refinery to slow down the growth but in due time, if the fuel is not maintained well or is kept too long in the tank, the organisms will still multiply and produce that brown/muddy crud that sticks to anything the fuel touches.
Diesel Bug Explained - Bacteria Contamination of Diesel - Freephone 8 933 939 for more info
And you can't opt out of the update.
National ID Law
