Results 1 to 10 of 35
- Aug 2010
- 24
May 20th, 2012 11:20 AM #1Hi. can anybody help me regarding Toyota Innova D4D power loss. Mine is Innova E manual 2006 model and has done 150,000km. Have replaced timing belt and reset warning light. I have new air cleaner and fuel filter. Scanner does not detect any fault. It starts easily and does not stall at all. I experience speed loss when going up an incline (C5 Ortigas flyover) where I have to shift to low gear to try to maintain speed. Have difficulty going up basement parking ramps and need some bwelo to manage to get up. Definitely not clutch problem since engine RPM goes down together with speed and may stall. It has very poor acceleration but seems to be fine at low driving speeds, say up to 40kph. But acceleration is very poor when I enter SLEX or NLEX. I will appreciate any help. God bless.
- Aug 2010
- 24
July 22nd, 2012 08:12 AM #2By the way, I have replaced the SCV with the new longer model type to no avail. Still poor or low power or acceleration though I can reach 100+kph on NLEX.
July 22nd, 2012 02:51 PM #4
per experience, such problems (poor climbing power) are usually connected to the injectors. Dirty injectors. Try to have Denso take a check at it if you can.
No turbo leaks? Turbo works fine?
- Mar 2009
- 19
July 29th, 2012 12:23 PM #6I think the culprit is your injectors. I suggest you to visit central diesel in quezon ave. corner sgt magbanua. I had the same issue like yours.
July 29th, 2012 11:14 PM #7
- Aug 2010
- 24
August 30th, 2012 07:43 AM #8Thanks a lot for your feedback. you and vinj are both correct. I managed to get my injectors cleaned at Motor Doctor in Antipolo for less than P2,000. It's a one to 2-hour job depending on how stubborn some bolts are and how long it takes to clean the injectors. Other shops offer to sell "remanufactured" injectors when in fact a high power ultrasonic cleaning will do the job. My Innova now runs quite fine.
- Aug 2010
- 24
August 30th, 2012 07:45 AM #9By the way I have some pictures of the injectors before and after cleaning. I just don't know how to post them here.
- Aug 2010
- 24
August 30th, 2012 07:47 AM #10
Traffic!
