Results 31 to 38 of 38
August 7th, 2011 05:02 PM #31
is this always available sa casa?
thats my problem now.....i didn't read the thread carefully....I only base it all in the pics on the first post....my problem now is that I have already bought a filter because I assumed that I have the same aircon component as the TS...which happens to be not...so now I need to do some retrofitting....
any other place where can I buy this cover on for the cabin filter?
- Mar 2004
- 89
November 3rd, 2011 04:16 PM #32sa casa po meron nyan...you just have to order kasi wala sila stock most of the time.
January 13th, 2014 06:16 PM #33
how often do you clean/replace your cabin filter?
what specific brand do you recommend?
puede bang diy?
January 14th, 2014 11:10 AM #34
Washable yung filter. Dip the filter in soapy water (preferably with dishwashing soap) for 5 minutes and use garden hose to lightly pressure wash it, then let it dry under the sun.
There are actually 2 types available in the market.
1. The foam/fiber type (somewhat brown-black color) - lighter and more air passes thru, washable but prone to damage due to soft filter material.
2. The filter paper type (whitish color) - a little heavier and less air passes thru and you'll need to wash this more frequently. Mahina ang buga ng aircon pag ito ang ginamit.
Sa mga mahilig sa DIY. Yes you can try using 1/2 to 1 inch thick foam pads of the same size provided you enclosed it with fine chicken wire - otherwise your foam pad will be suck by the blower motor and might cause damage
- Jun 2010
- 23
January 14th, 2014 11:47 AM #35Is this also applicable with the Toyota Revo (2002 SR)?
Sent from my COSMOS X2 using Tsikot Forums mobile app
January 14th, 2014 12:20 PM #37
What vehicle and what's your budget?
